Question about Garden
Pond pump spins but no water pressure? - Garden
    New Friend:
  • 21 Answers
It is either a broken impeller in the pump or if it was just drained or new install, then an air lock most likely. Try disconnecting power, then reconnecting, then disconnecting, etc. Until prime is achieved.
Posted on Apr 02, 2015
Flotec 1/6 submersible pump wont pump any water out of backyard. My hose ia 75 feet long. Should it be filled with water? I have serere ponding that will eventually go into basement. Pump is new.
Check the pump to see if their is anything stuck inside. Check to see if motor is even spinning, it might hum...but not pump or spin.
Mar 29, 2010 | Flotec Plumbing
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
With the water running the MQ pump runs intermittently
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Mar 09, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
House pressure water pump has to be reset to
it sounds like a relay for the auto shut off ....http://www.smarter.com/water-pumps/grundfos-mq3-35-3-4-hp-pressure/pd--ch-47--pi-11277834.html
Jan 16, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
How do you adjust the water pressure on a flotec fp4012-10 water pump?
You can not adjust the 'water pressure' the pump delivers but you can regulate the flow by installing a valve on the pump discharge and then partially closing it to reduce flow and increase pressure.
Jan 08, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Pump spinning but not getting up to speed then shuts off
You have a pressurized system using a pressure tank.This is a case of an air logged pressure tank. Meaning there is more air than water in the pressure tank. The pressure tank must hold 2/3 water and 1/3 air of its total volume. Installed at the tank is the air volume control to take care of this proportion. Should the air volume control malfunction or becomes defective, the air-water ratio is affected. And then,
the pressure tank becomes either air logged or water
logged.
SOLUTION:
1. Shut the power off, and open the discharge line
gate valve to flush the water in the pipe lines.
2. Open the drain plug of the pressure tank to empty
all the water at the pressure tank.
3. Close the drain plug, and put the power on.
4. Start the pump, and set the flow control valve 1/4
open.
5. The pump will normally run.
Send your e-mail for us to know the results, and for
further assistance.
Jul 04, 2009 | Plumbing
Our pond water pump has no pressure so we have no water
1. Pump burned up. 2. Check to see if there is something blocking the intake. 3. Plug it in to a well grounded electrical outlet. Hope you get it working.
Jun 13, 2009 | Garden
Pond pump trouble
take it apart and clean it with vinegar, then rinse with plain water. make sure to take the impeller and shaft it's on, out of the little cavity and give that a good wash too.
May 15, 2009 | Nursery Pro Inc 75gph Statuary Pump
Pump is not working, pressure gauge and pressure switch have been replaced.
the automatic pressure switch does restart the water pump when the valave is open?
Apr 26, 2009 | Garden
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
