Pump spins but water power very very weak/ - Washing Machines
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
It sounds like you have a loose pump impeller try checking the impeller while holding the shaft.
Posted on Mar 29, 2015
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
Washer won't spin
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
My washing machine wont wash or spin proprly
the water is not pumping out because you have a blockage in the filter unit which is located at the bottom of your machine or possibly a weak pump. the reason that your machine smells is because the water is not discharging. check the filter first for any blockages, i.e coins, bra wires etc. if that doesn't sort it you may need a new pump
May 12, 2012 | Hotpoint Ultima WF860 Front Load Washer
My sensing light stays on during wash cycle and dishes are not coming clean. The wash arms are not spinning very fast during the sensing nor the wash cycle. Not sure if it is the control board or the...
I do not suspect the control is the problem,it could be a weak pump OR not enough water in tub to be circulated. The water level should be at or just above the level of the heat element if it is less..the water valve is bad and not fully opening or the water supply into that valve is restricted
Gene
Aug 23, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
Will not drain. it does'nt look like its spinning very fast.
The washing machine not draining water.This problem is related to few possibilities. 1) The drain pump is got loose to the drain hose. check the connection from drain hose to drain pump. 2) The drain is blocked by any thing.Like cloth or any thing like metallic nails or coils etc etc. 3) The drain hose is got blocked./The drain hose is not letting the water to enter the drain pump. In most of the cases the drain pump has to be removed and checked for any kind of blockages.Also if the machine not draining can effect the spin cycle.But other possibilities for no spin or slow spin are faulty or broken motor coupler or weak spin motor.The motor coupler and motor both can be possible,if the drain pump and drain hose both checked ok.This will clear the fault. ----------- Keep updated with any more queries.Thanks,.
Oct 14, 2010 | Washing Machines
Sprayer arm is not spinning, water comes up through weakly.
your water supply is too low. he watervalve (inlet valve) may be clogged. With insufficent supply you get a low fill and not enough water to fully enage the pump's power.
Apr 08, 2009 | Dishwashers
My he3 washing machine does not spin all the water out
DOES IT SPIN UP TO FULL SPEED? IF SO YOU HAVE A WEAK PUMP OR A CLOG IN THE HOUSEHOLD DRAIN PIPE.
Jan 29, 2009 | Kenmore Elite 45986 Front Load Washer
Wash machine wont spin
Here are some reasons for not spinning
It does not have to be a motor!
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
Whirlpool/Kenmore- Weak Clutch Spring
If the clutch is slipping the spring is weak and must be replaced.
Check them out and see if this helps
Please leave me a rating before you sign off
Huum
Dec 07, 2008 | Whirlpool Washing Machines
Front Loader Wont Purge Water and enter Spin Cycle
it is the drain pump, it is nt working due to lack of power entering its supply line or there is something stuck in the impeller,or its winding failed, u can check it by observing or wait till machine reach the drain cycle when you hear a humming sound during the drain cycle, you isolated already the supply to the drain pump it means the drain pump is working but there is something blocking the hose,impeller and or the pump motor is weak already. if so, call an authorized servicer or service fr the company to do the job, or if u want to fix it by yourslf, first lay down the hose of the machine at floor level, water will comes out, drain it,with that it means no problem with the water line from the tub of the machine to the drain hose, remove the back cover from there u can see the pump get a mechanical plier to remove the clamp,slide the pump or unscrew it if is installed that way then u can check now the pump physically, sometimes small pins is blocking the impeller if there is nothing and when you touch pump is so hot-it is electrically defective-the winding is weak or just what i have said earlier it is blocked or mechanically defective -replace the pump assy- u can order it -try www. repair clinic .com
Apr 06, 2008 | Washing Machines
Pump won't empty machine
i had this problem once...either its the timer u turn manualy or the bottom of the big round thing that spins it is not spinning..the spin cycle is a whirlpool effect that pushes the the water up a tube and out....also lay the draintube on the ground...if water comes out slow ...something is weak.
Jun 27, 2007 | Kenmore Elite 21082
Washing Machines Logo
Top Washing Machines Experts
