Question about Water Heaters
Would a leaking pressure valve cause there to be no hot water? Both happened together.
    Sergeant:
  • 192 Answers
On a hot water tank it could be your panel breaker flipped off. Push the breaker to off and they back on. It could be that one element was burned out a while ago and now your second element has burned out also. The most likely situation could be that you turned off a valve to the tank, the water leaked out of the tank and the elements then burned out trying to heat only air.
Posted on Mar 29, 2015
Testimonial: "We have not touched/ turned anything on or off on the tank. Discovered no hot water this morning and the pressure relief valve leaking when we looked at the tank."
My hot water tank is continually leaking ? I shut off the valve at the top of the tank and it is still leaking ??
They wear out especially if they are older. You did not say what make and model it is but if there is water coming out the bottom it is time for a new unit. The leak is still happening because even though there is not supply pressure, gravity is pulling the water out the break in the liner.
Jul 05, 2016 | Water Water Heaters
Rheem 71 30d
You should be able to control hot water temperature by adjusting the thermostats. Either or both may have failed, causing heating to increase to the maximum. The "spitting" is caused by boiling water. Likewise, the pressure relief valve is operating as it should resulting in the overflow you observe. You need to get your heater serviced immediately!!
Oct 10, 2013 | Rheem Tankless Hot Water Heater...
I have a GE Profile Water Heater Model #SE40M12AA01.
I recommend safety changes to prevent ruptured water heater and assorted leaks.
135 degree hot water.
Maybe replace TP valve if it is dripping.
Drip pan under water heater with 3/4" drain line to outside.
Expansion tank on incoming cold water line to absorb pressure build-up, and prolong life of tank and plumbing.
Here's why:
1) Yes you can have scalding hot water.
2) I recommend 135 degrees since that will burn the evil right out of ya. And generally kill clothes washing bacteria.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) 150 is dangerous and can seriously burn skin in 1.5 seconds. Not safe around children and elderly.
4) Temperature settings on electric water heater are approximate, since thermostats are calibrated approximately, and read temperature through tank wall.
5) Also if you want to increase amount of hot water for high-consumption household, then setting tank temperature upward is one solution since more cold water is mixed with hot, so amount of hot inside tank goes further.
6) High temperature can cause TP valve to release water.
TP valve is pressure-temperature safety valve. Do NOT cap off.
Rating should be 125 psi and 180 degrees ... but all things water heater are approximate, and TP valves need replacement now and then.
It is not recommended by water heater manufactures to use 150 psi TP valve when water heater came with 125 psi. Rating shows in small print on end of TP. New TP valves sold at local hardware. Let tank cool before installing new one.
7) Higher temperature and high pressure can rupture tank.
Pressure over 80 psi shortens life of water heaters and plumbing fixtures. Put BTG100 pressure gauge on water heater drain valve to check pressure.
8) You need a drip pan with 3/4" drain line to outdoors, or to drain vent line, to prevent flood caused by ruptured water heater.
Turn water heater off when going on vacation.
Inspect water heater each 6 months.
Drip pan available at local home center or hardware:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#drip
9) Heated water expands and puts pressure on tank and pipes.
Water does not compress... so when water gets hotter it expands against tank wall and against pipes.
Especially in closed system (check valve present) when system is without expansion tank.
Expansion tank is installed on incoming cold water line.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#expansion
Oct 31, 2012 | Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    I have a hot water heater that when running seems to build up an excessive amt of pressure. We just replaced the pressure valve because the old one started leaking when the hot water was running for any...
    The most likely problem is that the thermostats are set too high. Remove the thermostat cover plates and look to see where the thermostats are set. The range should be between 120F and 135F. Liquids expand with heat so the higher the temp, the high the pressure. Decrease the setting on the thermostat until the leak stops.
    The other likely cause is a head of air trapped in the top of the tank. After drawing hot water, it wiill be displaced by the incoming cold makeup water. This will compress any air in the top of the tank. As the water heats, the air will heat and pressure will build - possibly causing the leak. You can purge the tank of air by opening the pressure relief valve until water comes out (which I assume that you have already tried).
    Dec 09, 2010 | Whirlpool Water Heaters
    Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
    It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
    There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
    Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
    If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
    Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
    Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
    It sounds like two problems.
    Problem 1) Clog inside faucet or clog inside pipes at faucet
    Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
    My bet is clog inside faucet.
    If you have galvanized pipe that meets copper pipe, this can be trouble spot.
    Article on clogged water pipes at Inspectapedia:
    http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
    Article on clogged pipes:
    http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
    Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
    If cold water shut-off is leaking, then replace shut off.
    If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
    If TP valve is leaking, then replace with same temperature and pressure rating.
    New TP valve threads need teflon tape to seal pipe.
    Problem 3) If pressure is low all over house:
    Buy pressure gauge at hardware store that screws onto hose connection.
    Test pressure on outdoor spigot.
    Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
    Test pressure on water heater drain valve.
    This says if pressure problem is before -or- after water heater.
    If problem is before the water heater, then shut-off valve located on cold water line is suspect.
    If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
    Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
    Read articles above about clogs inside water lines.
    Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
    The temp./pressure valve on top of the heater is leaking. what is the cause and solution.
    It is possile that it had apressure fluction for various reasons. It's also possible that valve spring is just getting weak. What i would do first is replace T&P valve and see what happens.These are common 3/4 inch male iron pipe t&p valve available at most hardware stores. First shut off water supply to water heater, then open valve on hot water side of nearest faucet to relieve pressure. Remove old valve by turning counterclockwise. You may need a pipe wrench as they can be pretty tight. Remove old t&p valve and use teflon pipe tape or joint compound on new valve threads. Install new valve and tighten securely. Close faucet previously opened to relieve pressure,then turn water supply valve to water heater. Check for leaks and tighten further if needed. Check valve occasionally for next couple days. If no further leaks from valve then your're in business. Hope this helps. Thanks
    Nov 11, 2010 | RELIANCE ELECTRIC WATER HEATER
    Rheem hot water heater problem
    If by the hot water over flow valve you are refering to the T&P valve. It is activated by high temp. or high pressure. It is possible that when you flushed the lines it caused this to open. It is also common for these once open to get a little debris in them and cause them to continue to leak. Sometimes you can open and close them a few times and get them to reseal. Other times you have to replace them. Hope this helps.
    May 07, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    Hot water not very hot..also seems low in pressure
    pressure temp valve leaking
    tank leaking
    hot water line leaking
    shut off water to tank and leave sit for 4 hours turn on water tap and test temp if hot you have a leak
    Oct 17, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    Water Heaters Logo
    62 people viewed this question
    Top Water Heaters Experts
    Paul Carew
    Gil Shultz
    Are you a Water Heater Expert? Answer questions, earn points and help others
