Question about Netflix
Why is there no picture but sound?
I have been a customer for a long time. I'm getting sound but no pix
    Novelist:
  • 201 Answers
Can you tell us a bit more about the problem? It would be helpful if we knew:
1) What device are you using to connect to Netflix (computer, DVD player, TV, etc.)?
2) When you use that device for something other than Netflix, do you see a picture? So if you're using a DVD player, can you play DVDs? Can you watch TV?
3) Can you log into your Netflix account on your computer and watch movies on your computer? Can you login from someone else's computer and try that?
3) When did the problem start?
Some shot-in-the-dark steps that apply to all electronics:
1) Turn everything off. Turn it all back on.
2) If that doesn't work, unplug everything. Wait 30 seconds, then plug it all back in.
3) Check all the cables (from power to your TV and Netflix device, cables coming from your peripherals to the TV, etc.). Even if they seem to be well-seated, unplug them and plug them back in.
4) Try new connections. If your TV was connected by HDMI, and you have a different way of connecting your device (DVI, component, RCA, s-video, coax, whatever) try it. If your device connects to the Internet wirelessly, see if you can get a wired connection. Swap cables wherever you can.
5) If you can, try interchanging components. So, for example, try connecting to a different HDMI port on your TV. Try other devices on your TV. Take your Netflix device (if it's not your TV) to a different TV.
Those last 2 steps may solve the problem, but are more likely to isolate the problem. (For example, if your DVD player doesn't work no matter what TV it's connected to, then the problem is the DVD player.)
Update us with as much info as you can.
Posted on Mar 29, 2015
Pictures will not pull up
hi, i had trouble getting the computer to recognize the camera to get the pictures off. it seems that the drivers for the camera were not included on the install CD, but they can be found here:
http://digiblue.com/customer-service/downloads/
just click on the first download under the "Driver Downloads" section.
Hope this helps.
Jun 21, 2009 | Disney Pix Click Digital Camera
Can't find a driver to download pictures to my computer
This should help you out. http://digiblue.com/customer-service/downloads/drivers/pmbv.html
Good Luck
Mar 02, 2009 | Disney Pix Click Digital Camera
Downloader says no pictures on camera
Had the same problem till I found the right drivers to run this camera, but if you want to save yourself time and headaches its now worth it Im taking mine back, Ill spend a lil more and get them cameras that work, they dont need Hannah Montanas picture on it anyways. for the manuel to work this fancy gadget go here ....http://digiblue.com/customer-service/downloads/index.html to get the right driver for windows XP go here should work
Dec 27, 2008 | Disney Pix Micro Digital Camera
Trouble downloading Pictures
this was found on another solution from ncmerc on Fixya
1) Connect the camera with the provided USB cable.
2) Download the latest driver from the Digital Blue web site: http://digiblue.com/customer-service/downloads/index.html, select the "The Disney Pix Micro Drivers for WIN ME, 2000, XP"
3) Install this driver, this will not enable the camera to work yet.
4) After this driver has installed, go to Control Panel
5) Select System
6) Select the Hardware tab
7) Select Device Manager
8) Find the device in the list (mine said "USB Digital Still Camera"),will probably have the yellow exclamation mark on it saying that it isnot working.
9) Double click the device
10) Select "Reinstall Driver" from the General tab
11) When asked if Windows can connect to Windows Update to search for software, select "Yes, this time only" and click Next.
12) Choose "Install the software automatically" and click Next.
13) You should get a message saying the driver for the "DB CIF Cam" hasnot passed the Windows Logo testing, select "Continue Anyway".
14) Click Finish.
15) The first time I did this, I needed to take a picture while the camera was connected to the PC.
After doing this I am able to download the pictures and everything works great. I hope this helps.
Oct 31, 2008 | Disney Pix Click Digital Camera
DISNEY PIX
After searching for an hour, I found the User's Guide. Here's the link: http://digiblue.com/customer-service/downloads/qsg/Disney_Pix_Click_Guide.pdf
Happy Picture Taking!!!
Oct 01, 2008 | Disney Pix Click Digital Camera
Disney Pix Micro Digital - stopped working after 10 minutes
The type or memory in the camera requires a charge in order to store data. So if you have any pictures on the camera it will constantly be pulling a charge from the battery until the battery is completely drained. If you have this problem even with a brand new battery it's possible that the memory may be corrupt and needs to be cleared. To do this just remove the battery and press both buttons several times each to make sure that the camera is completely discharged, replace the battery with a brand new battery and try again. If that fails I'd get in touch with customer service for a replacement.
May 18, 2008 | Disney Pix Micro Digital Camera
Disney Pix download
Hi Leewolf,
Try this solution that was previously posted on FixYa:
My daughter just received one of these camera's for her 6th birthday and is extremely excited. I am running Windows XP and was getting the "No pictures on camera" error. I tried downloading the drivers for this but that did not work. Here is what I did to get the camera working:
5) Select System
8) Find the device in the list (mine said "USB Digital Still Camera"), will probably have the yellow exclamation mark on it saying that it is not working.
13) You should get a message saying the driver for the "DB CIF Cam" has not passed the Windows Logo testing, select "Continue Anyway".
14) Click Finish.
May 16, 2008 | Disney Pix Micro Digital Camera
Photos
What is PIX Place? Pix Place is an online service that is included with each activation of Picture/Video Messaging. At the Pix Place web site you can:
  • Store your favorite picture/video messages from your picture/video messaging phone*.
  • Create and name your own online photo albums*.
  • Upload and send images from your computer's hard drive.
  • Invite friends and family to view albums*.
  • Create your own picture/video messages online with your own pictures/videos, sounds and text.
  • Enhance your picture with "Fun Effects" like brightness, crop, antique, black & white, soft focus, comic bubble, cartoon, and line drawing effects.
  • Choose images and sounds from the free "Gallery" to include in your messages.
*Pix Place registration required.
Note: Not all picture messaging phones have video messaging capability. However, all video messaging phones will have both picture/video messaging capability.
HAPPY NEW YEAR
Dec 24, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Screen Blinking
It is in truth,the picture tube,but it would be helpful for repair shops and independent techs to educate the customer as to the investment risk of repairing an older "S or V" model Sony. Generally,the pix quality deteriorates gradually before the Ik circuit senses the problem and cuts off the pix.Unfortunately,you were not able to observe any pix problem because the set was dead when given to you.The power supply repair was obviously needed,but the pix tube condition was unchecked/unknown.Before spending any money on repairs,try to find out the historicity of a particular make/model from a willing,qualified technician.
Oct 05, 2007 | Sony KV-32S26 32" TV
Camera takes one picture
Get onto Nikon Customer Support this is a main board problem
Jul 09, 2007 | Nikon Coolpix 5700 Digital Camera
Netflix Logo
129 people viewed this question
Top Netflix Computers & Internet Experts
David Payne
David Payne
LP
arcada
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
