Question about Singer Sewing Machines
How do I correct singer 1507 which suddenly started sewing continuously in reverse and not forward
    Sergeant:
  • 192 Answers
It could be a thread got caught on the reverse switch and pulled it into reverse while sewing.
Posted on Mar 29, 2015
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
bilabon
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
  • 240 Answers
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Posted on Jun 11, 2009
  • 1788 Answers
SOURCE: Will not sew in reverse.
sometimes it is the spring, open the machine up and take a look at the spring, it may be broken or stretched. It should be located right where the reverse lever is, inside.
Posted on Aug 04, 2009
  • 4 Answers
SOURCE: manual for singer 1507
I scanned my manual and uploaded it to a file sharing site here is the link to the file:
www.4shared.com/file/133426020/8af58505/Singer_1507_manual.html
I only scanned in the English pages, I hope that is not a problem.
Posted on Sep 17, 2009
How to oil my machine singer 1507
Follow the instructions in the owner's manual. Computerized machines do not require the extensive oiling that older mechanical machines need. Be sure to use the correct oil for your machine.
Oct 11, 2016 | Singer 1507
I recently bought a Singer 1507, I sewed few seams and then the thread tangled underneath, the needle stuck and it took some time to free it. I was unable to fix the problem even going through all p
It is most likely the bobbin not right I'll send u a pic also make such it's not in reverse after u insert the bobbin hand turn it one the need will go down and pic up the bobbin thread once it does pull up on needle thread and it will come up with it all way start with bottom and top thread out the back also make sure tension is set or it will wad up
/uploads/images/recently-bought-singer-1507-sewed-few-34846443-1-1.png
Jan 06, 2015 | Singer 1507
Singer 4166 suddenly started sewing only in reverse even when forward mode checked
open the top of the sewing machine. Then press the button or lever that changes the forward reverse mode. You may find that something got stuck there where it should effect the machine part. May a drop of oil on that spot can help?
Jan 11, 2014 | Singer 4166 Sewing Machine
Brand new Singer 4423 won't go in reverse ?
Your reverse lever may have become disconnected inside the machine. Return it to the dealer if you don't want to fix it yourself.
Jul 29, 2013 | Singer 4423 Sewing Machine
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
1507 singer wont stitch
it would be a good idea to change the needle
rethread the machine using every thread guide
make sure the bobbin is turned the correct way in the bobbin case
and that the bobbin case is correctly inserted into the machine
it's also possible that the machine could have jumped time and
needs to be checked at a sewing machine shop.
Apr 16, 2013 | Singer 1507
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
Jan 06, 2013 | Singer 1507
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
Where can I get a Singer 1507 sewing machine manual in Russian
Okay, I looked for a while to find you a manual, but of course there isn't one in Russian. Here is what you can do though...
1. Locate your manual at the following website:
http://homeappliance.manualsonline.com/manuals/mfg/singer/ singer_product_list.html?s=gg314159
2. Use this website to translate the manual from English to Russian
http://babelfish.yahoo.com/
I Hope this helps :)
Sep 17, 2009 | Singer 1507
Manual for singer 1507
Mar 20, 2009 | Singer 1507
Sewing Machines Logo
56 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
