Question about Dishwashers
Will not start, some of the other buttons do light up when pressed but not all is there a reset sequence I can try? Thank You
  • 682 Answers
Open the door make sure there is nothing in the way. Then close it a couple of times, it is probably a door switch not making. I did this to mine once after tearing it half apart (never fixed anything really) and it started right up.
Posted on Mar 29, 2015
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Clean light is flashing and unit not starting.
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Feb 17, 2011 | Dishwashers
Light for clean is always on - start button will light but not hold - do I need a repair person?
Clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 12, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
It won't start. The clean light is blinking but it won't reset to start a new cleaning cycle. the cancel function work and it will drain the basin but that is all.
Kevin
Dec 11, 2010 | Dishwashers
Clean light is flashing machine won't start
Kevin
Dec 09, 2010 | Kenmore Dishwashers
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
Kitchenaid dishwasher mdl: kud101t jbt0
try the reset button sequence.. described in that other post about the clean light blinking.. that will reset the whole machine..
tpug
Jul 07, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Flashing 4-H error message
try this reset procedure. Most likely this will work.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Nov 29, 2007 | Sharp AL 1631 Copier
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
