Why doesn't the monitor turn on? Power and earth present.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
Check Data cable of monitor if it is attached to the source like CPU or any thing else. If connected then there is problem with the main power circuit board of the monitor. May be capacitors of power board are leaked which generally cause No power. See following images
Why doesn't the monitor turn on? Power and earth p - 25615093-0cck3zml0ywkxc1z4hxg0g1l-4-0.jpg
25615093-0cck3zml0ywkxc1z4hxg0g1l-4-2.jpg Why doesn't the monitor turn on? Power and earth p - 25615093-0cck3zml0ywkxc1z4hxg0g1l-4-5.jpgt/uploads/images/25615093-0cck3zml0ywkxc1z4hxg0g1l-4-5.jpg" alt="25615093-0cck3zml0ywkxc1z4hxg0g1l-4-5.jpg" class="h_mi" />
Posted on Mar 31, 2015
My crt monitor is not working, its power button light will be on when cpu is not turned on, but when cpu turned on , the monitor is continously turning off and on, please help me...
why in the world use any 20 year old CRT monitor
its a fire hazard now , bet you !
if it fails on PC #2 the monitor is bad.
is this test hard? with billions of PC on earth.
tell me it is not.
btw no HP model number stated
of of the OSD menu button works ever.(monitor button)
Sep 04, 2015 | Compaq Computers & Internet
Doesn't turn on
Gain access to the electrical connection with voltmeter set to 110 v ac check for voltage on both sides of switch. If voltage is present on outlet side follow output wire to start relay ck for power on out put side of relay. if power follow output wire to motor if voltage is present replace motor ! Be careful where you touch when probing contacts !
Dec 29, 2012 | Kenmore whispertone 100 model 116
Samsung TFT 19 LCD no flashing red LED continues on replaced all caps
did you check the output dc voltage of the power supply if present. if ok, then doesn't turn on the problem is with in the main board.
Oct 10, 2012 | Computers & Internet
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
My brake lights do not work everything else does replace flasher unit and brake light switch checked all fuses and wiring all seem good on a 97 eclipse
If lights don't work, they either have no power, or no return earth. Therefore, remove a stoplamp globe and measure the voltage present in the globe socket. Next with a mutimeter, or battery powered light circuit, check that the globe sockets are in fact earthed to the frame.. If the earth is ok, and there is no power present, then you have a break in the wiring between the stoplamp switch and the rear of the vehicle.
Mar 18, 2010 | 1999 Mitsubishi Eclipse
While working on PC der was spark at plug point and now monitor is not turning on.
u need to either change the power cable of the monitor or go for a repair of the LCD.
the power cable may have been spoilt most probably,use earthed sockets for ur PC and check lose connections.
i myself had experienced this problem earlier due to improper earthing
Jan 13, 2010 | Acer AL1716 17" LCD Monitor
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    Monitor does not turn on automatic
    change your power cable.
    also check your power suply and earthing.
    Nov 19, 2008 | Princeton Digital VL2018W Monitor
    Display works - but only for a plit second...
    Lower your resolution on your computer. Usually when that happens the resolution is set higher than what the monitor can support. Lower the resolution and try again.
    Jul 25, 2007 | Dell E173FP 17" LCD Monitor
    Computers & Internet Logo
    64 people viewed this question
    David Payne
    David Payne
