Question about Canon PIXMA Office Equipment & Supplies
Can I fix my printer, it scans ok but prints blurry?
I tried to move the cartridges from right to left to change the inks as they were stuck.
    Master:
  • Canon Master
  • 432 Answers
Try to move the cartridge with the printer turned off
Posted on Mar 29, 2015
Print head parked at left, error code 3527
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Dec 27, 2013 | Kodak ESP 7250 All-in-One InkJet Printer
Kodak esp 7250 printhead carriage jam
Mar 09, 2013 | Office Equipment & Supplies
Kodak 7250 print head jam
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
I just changed my ink cartridge on my F4280 hp printer, now my printing is blurry
Hello.
Try running the print head alignment feature through the computer. (Click Start - Control Panel - Printers and Faxes - RIGHT CLICK HPF4280 - select printing preferences - select maintenance - select cartridge alignment and follow the on screen instructions) This can also be caused by solid pieces of ink stuck inside the print head disrupting the flow. if it a genuine HP cartridge contact HP for a replacement. The link below shows how to clear blockages also http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
May 28, 2011 | HP DeskJet F4280 All In One Printer InkJet
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    Dell 922 printer alignment problem-
    try this...
    Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
    You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridges:
    2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
    3. Click the Maintenance tab
    4. Click Align to fix blurry edges.
    5. Click Print.
    The ink cartridges align when the page prints.
    If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
    Feb 01, 2009 | Epson Printer
    Clear the carrier jam
    There could be 4 possibilities.
    1. Ink cartridges lids are open which is not allowing cartridges to move freely.
    2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
    3. Encoder strip is Dirty.
    4. Encoder strip is Out of position.
    Solution:
    1. Open the front cover and check if ink cartridges lids are properly snapped in.
    2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
    Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
    3. Cleaning the encoder strip:
    a. printer should be off and disconnected from power.
    b. open the front cover.
    c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
    d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
    e. Close the printer and try again to print.
    4. Repositioning the Encoder strip.
    a. Remove the power cord from the printer.
    b. Open the front cover.
    c. Gently slide the ink cartridge carrier to the middle of the printer.
    d. Gently move the top part of the printer belt to the right.
    e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    h. Once the encoder strip has been re-seated, close the scanner lid.
    i. Re-connect the power cord to the printer and try again to print.
    Incorrect position of encoder strip
    Correct position of Encoder strip
    Hope it should fix the issue.
    Sep 01, 2008 | Dell 942 All-In-One InkJet Printer
    CHANGING INK CARTRIDGES
    For all printers I'm familiar with, it should be on. Some won't even move the carrier (the sliding thing the ink carts go in) over to where you can get to it if you open the cover with the power off. And you'll want to print an alignment page after replacing a cart too or your printout may be blurry (most printers will prompt you to do that after you close the lid).
    Aug 05, 2008 | Office Equipment & Supplies
    Print cartridge cradle is stuck ican't find where it is jammed
    This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
    Apr 16, 2008 | HP Office Equipment & Supplies
    50 people viewed this question
    old marine
    old marine
