Question about Hasegawa 1/48 F/A-18C Hornet 07250
Dear sirs, would it be possible to purchase part No.B1 (upper fuselage part), as i have made a bit of a mess trying to fit Aires resin parts
My name is Douglas Ewing My address is 61 main road,Hambleton,Selby,North Yorkshire YO8 9HW PHONE 01757 228276
Hello. why cant i use the round over bit i bought.
You must purchase a sub base (part number 42188) with a larger hole, it has a 2 1/2" hole, for the bit to fit through.
Oct 12, 2014 | Porter Cable Tools & Hardware - Others
Is there a replacement titanium watch band for a casio PRW 5100-1
If the watch band attaches like most resin bands do (springbars) then all you need is to buy any titanium band that is the same size. Measure the width between where the band attaches in millimeters, that is the size you need. Brand doesn't make a difference in the fit unless it has a special band made as part of the watch, and resin bands aren't like that, they're just standard sizes
Mar 24, 2014 | Casio PROTREK Triple Sensor MULTIBAND6...
Can you remove resin from a electronic board?
Once resin has cured, removing it is involved and difficult. Typically Muriatic Acid can dissolve the resin - BUT it will also dissolve the board! Using Paraffin on the board parts you don't want ruined may help keep the Acid from eating the board, and the fumes from the Acid are hazardous. Great ventilation and a respirator are recommended, and it may take several applications to get that resin off. neutralizing the Acid is necessary too, to keep it from continuing to eat away at the board. You may be better off replacing the board, as that would be much healthier!
Hope this helps!!
Dec 17, 2013 | Parts Unlimited ATV OIL FILTERS -...
What is the fuselage part of the airplane?
The fuselage is the body of the airplane. It includes the cockpit, the cabin, and the cargo of the plane. Depending on the type of airplane, the fuel could be stored in the fuselage.
Aug 29, 2012 | Champion Sport & Outdoor - Others
Front fender is cracked and rubs, know this is a common problem, is there another fender that fits this bike
Here is a link to a new one but it is $180
http://cgi.ebay.com/ebaymotors/Yamaha-1986-1987-YX600-NOS-Front-Fender-J-M_W0QQcmdZViewItemQQhashZitem48396ec7ebQQitemZ310201206763QQptZMotorcyclesQ5fPartsQ5fAccessories
These are the models it will fit:
Part # = 1UJ-21510-00-MW
Part Description = FRONT FENDER COMPLETE
YX600S 1986 600 YX600 RADIAN Street
YX600SC 1986 600 YX600 RADIAN (Cal) Street
YX600T 1987 600 YX600 RADIAN Street
YX600TC 1987 600 YX600 RADIAN (Cal) Street
To try to find one that would fit the same that is not made for the bike you would have to actually compare your cracked one with the others. If you call a Yamaha dealer they will most likely want to sell you a new one, but they may give you a cross reference for other models that will fit.
Please vote for me and rate me if this helps,
ETRONIC
Mar 15, 2010 | 1987 Yamaha YX 600 Radian
Royal Albert China Teapot has a small piece broken at top where lid fits. I have the pieces. it is at the back of teapot near the handle Measures abt. 2mm x 2mm. There are three pieces and some slivers . I...
Get some araldite (epoxy resin) mix equal quantities of the resin and the hardener and somehow glue it together. This stuff is strong once dried and is heat resistant and as far as I know...non-toxic once dried.
It will be a bit fiddly though, and you should use a little hand held clamp to keep the pieces together as tightly as possible until it hardens.
Sep 16, 2009 | Computers & Internet
Resin in soft water
Curious if you have had any resent well pump issues, low pressure lost pressure? Has the well pump gone done (possible vacuum created drawing out resin)
Often water softeners will have a bye-pass on them. I would try bye-passing the softener for a bit, run the water (and the pump) for a while clearing your system of any resin. I'd open bath tub valve or better yet an outside garden hose (watch for resin)to avoid plugging a aerator. If you see a significant pressure gain it could be that your softener has some plugging> In some areas of the U.S. Iron Bacteria has formed in aquifers which with time will plug a softener along with piping. If this is happening you will have to treat your well, this is done with chlorine (please use a professional here, we are talking about your drinking water) If this is happening the well will need to be treated once or twice a year.
I hope this may have helped,
Tom
Please start with the bye-pass on your softener, if your water pressure is greatly better you have narrowed down to where your problem is
Sep 11, 2009 | Plumbing
Glasses on top shelf
possible grit you are feeling is from the water softener breaking down. the softener contains a brown resin. this ofted happens if you have connected supply to hot water. best connect to cold
Apr 25, 2007 | Hotpoint 24 in. HDA2020Z Built-in...
Hasegawa 1/48 F/A-18C Hornet 07250 Logo
413 people viewed this question
Top Hasegawa Sport & Outdoor - Others Experts
Bill Eager
Are you a Hasegawa Sport and Outdoor - Other Expert? Answer questions, earn points and help others
