Question about Toshiba 36A40 36" TV
A tv no longer high lites why? - Toshiba 36A40 36" TV
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
I turn on tv shuts off after 30-45min. red lite goes dim
It's likely that the TV will require service since your troubleshooting steps didn't resolve the problem. If your TV is smaller than 30", you may carry it in to the retailer of purchase for repairs. Otherwise, service for your TV can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Nov 19, 2009 | Televison & Video
Sony kp61hs30 standby/timer lite flashes 8x and tv shuts off
The 8 blinks usually mean that there is a problem with the high voltage section of the set. This can be the flyback transformer or other parts in the same horizontal circuit. This is not a repair that I would suggest be attempted by non-service personnel. Expect a parts cost in the $100-$150 range plus the local labor rate.
Dan
Jan 28, 2009 | Sony KP-61HS30 TV
Sony trinitron,standby lite flashes
Hello mybuddydakot,
This is an indication that the shutdown circuit is functioning which means there is a high current event happening in your set. I would venture to say that the problem may be in your high voltage section. I would suggest that you take the set to a qualified TV repair shop, due to the nature of this possible problem.
The High Voltage section is dangerous and should be worked on by a person who has knowledge of television electronic technology.
I hope this helps,
Shuttle83
Nov 18, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
NO PIX NO SOUND
I have searched high and low in all the documentation for your T.V., which is why it has been so many days since you posted your request for assisatnce.
Have you tried turning the TV on with both the remote and with the buttons on the TV? I'm betting you have, but I need to ask.
I would suggest that you unplug the TV for at least 24 hours to completely clear the memory of everything. This might reset the unit so that it begins working again.
However, my bet is that your power supply is dead so that it cannot power up the TV at all. Unless your TV is still under the warranty I think the only options you have are to either have the TV repaired by an authorized servcie technician or to buy a replacement TV.
Sorry I don't have better news to offer you.
Jun 18, 2008 | Sony KV-32V42 32" TV
LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Jun 05, 2008 | LG 47LC7DF 47 in. LCD HDTV
Curtis-Mathis CM25011 25" TV
Your electron gun is failing. Throw it away!!!!!!!!
Mar 23, 2008 | Curtis-Mathis CM25011 25" TV
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Toshiba 36A40 36" TV Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
