Question about Vehicle Parts & Accessories
I rebuild a triumph spitfire 1500 engine and the bottom aed is knocking can anybody help
    Master:
  • 602 Answers
Crank shaft has a flat spot from when the engine was knocking before. you need a crankshaft kit. It comes with new rod and main bearings. There is no easy fix.
Posted on Mar 30, 2015
1974 truimph spitfire mk4 firing order
Edward, Firing order 1-3-4-2 for spitfire. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine Tuning Data for the Triumph Spitfire and GT6
Distributor drive gear and firing order question Spitfire GT6 Forum...
getting spark plug wires back in the right order MGB GT Forum MG...
http://www.repairservicemanuals.com/Triumph
Jun 14, 2016 | Triumph Cars & Trucks
What two wires go to the back of the speedometer, in a 1975 triumph spitfire 1500?
Hi Brian:
Gotta love old Triumph cars and lucas wiring! Well, maybe love the car and hate the wiring.
I've got a '73 GT6 MkIII to restore when I decide to retire, and I did a GT-6 a few years back.
If I'm remembering correctly, the speedometer has a manual drive off the transmission so the only electrical wire to the speedometer would be for the light. Makes sense since there are separate lights for each gauge.
Please reply as a COMMENT to this post.
Cheerfuls.
Mar 15, 2016 | Triumph Cars & Trucks
My 1969 triumph spitfire has been running fine but lately has started suddenly cutting out and losing power under heavy uphill loads. When this happens it always blows oil and smoke out aroumd the bol
time to rebuild motor or replace it. The smoke your seeing is pressure from the cylinder escaping around the piston rings into the crankcase and venting out the covers
Aug 24, 2014 | Cars & Trucks
Where is the fuse located for a 1976 spit fire 1500 wiper motor
Firewall drivers side of engine compartment A weak point in a spit to say the least. Each of the legs on the fuse holder is a separate circuit. If you test the top leg it does not mean that the leg on the bottom is working. 1 fuse for two circuit will make you crazy if you do not know that detail.
May 10, 2014 | 1975 Triumph Spitfire
Fh41825he engine number what cc
The F series engines are from Triumph Spitfires. FH is a 1300cc engine (1296cc) from a Spitfire Mk4. I can't remember if it's a small crank journal engine like the Herald 13/60 GE engine (good) or a large crank (not as good).
Mar 04, 2013 | Triumph Spitfire Cars & Trucks
How do i wire a smiths tachometer in a triumph spitfire 1500
easy... remove the mechanical tach and fit the light from the old one to the new eletric tach. Next run a wire from the back of the tach connection that looks like a small pole and run that to your ignition coil - negative side. Also make sure the ground wire (black) is mounted to one of the install bracket posts that hold the tach in place behind the dash.
Jul 22, 2010 | 2006 Triumph Tr 7
I have a 1976 Triumph Spitfire 1500. It will ...
On older model vehicles we start having lots of electricle issues. the current flow gets interupted and broken because ALL of our GROUND wires get corroded where they are screwed to the body or frame. it is important that these connections get sandpaper shiny cleaned and tightly screwed backin. solves many issues.
Apr 07, 2017 | Cars & Trucks
Hi, I have a Triumph Spitfire 1500. There is no gate between the forward gears and reverse. Can anyone help me identify the fault? Thanks John
Hi, do you know if it is a single rail or 3 rail box? The single rail has the gearlever coming out of the tail housing ( and the reverse spring below the lever on the l/h/side sometimes replaced by the reverse light switch) the 3 rail box has an extension housing holding the gear lever, bolted on with 4 studs to the gearbox. this has a detent on the gearbox top plate.
Mar 06, 2010 | 2006 Triumph Tr 7
Vehicle Parts & Accessories Logo
89 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
