When I turn the washer on it fills but then does not stop I have tested the pressure switch what else controls the water solenoid ?
  • Washing Mach... Master
  • 5,323 Answers
IF NOT THE PRESSURE SWITCH I SUSPECT UR WATER INLET VALVE OR CONTROL BOARD ISSUE.
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Posted on Apr 16, 2015
catriver
  • 878 Answers
SOURCE: Washer won't stop filling with water.
slick, first see if the hose came off the pressure switch. Just grab the end caps on each end of the control panel and pull them off, they snap on. Remove the two consol screws, pull foward and flip the consol up. See if the hose came off. If it did, just put it back on and use a zip tie to secure it. See attached photo. Catriver...post back.
Posted on Mar 18, 2007
BIKER T
  • 909 Answers
SOURCE: Will not Fill
BELIEVE IT OR NOT, THOSE TWO ITEMS THAT WERE REPLACED SHOULD HAVE RECTIFIED THE PROBLEM.ONE NEEDS TO KNOW IF THE BOARD THAT IT WAS TESTED WAS IN EFFECT A NEW ONE OR NOT. IF IT WAS I WOULD SUGGEST DISCONNECTING ONE HEATER WIRE (IF HEATER IS USED) THEN PULLING THE PR.SWITCH PIPE OFF FROM THE TUB AND SUCKING A VACUME ON THE PIPE. THIS WILL INDICATE A LOW LEVEL CONDITION AND ASK FOR MORE WATER.IF FILLING TIME IS THEN RUNS FOR A LONGER PERIOD, THEN THE PROBLEM IS WITH A DEFECTIVE PR.SWITCH. HOPE I HELPED?
Posted on Jul 19, 2007
reg501
  • 413 Answers
SOURCE: washer won't stop filling
Remove the pressure switch hose and blow into it. Is it hard to blow through?
In the bottom right rear of the outer tub there is an air dome where the other end of the pressure switch hose is connected. The air dome can become clogged and prevent the pressure switch from working properly.
Also inspect the hose for any cracks splits or pin holes.
To access the air dome remove the cabinet shell as follows:
I will skip console removal as is seems you already know how...
With the console lifted;
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
In the bottom right rear of the outer tub you will find the air dome.
If I can assist you further, please let me know
reg501
The FixYa Team
Posted on Jun 22, 2008
SOURCE: My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Posted on Apr 04, 2009
  • 1417 Answers
SOURCE: My Kenmore washer would not
Hello.
Kenmore washer come in a variety of s and styles,including extra-large dishwashers and dishwashers that are accessible for thedisabled.
A Kenmore washer automatically resets itself every time a washingcycle completes.
If you want to reset an Kenmore washer in the middle of acycle, you can easily do so. Resetting a Kenmore washer takes only a fewseconds to complete.Instructions.
1 Press the"Start/Stop" button.
2 Hold the buttonfor three seconds and release.
3 Select the program and options on the frontpanel you want the dishwasher to use. Press "Start/Stop" to restartthe dishwasher. You have now reset a Kenmore washer Thanks.
Posted on Jul 30, 2011
Water continual running piease help
The Water Inlet Valve on your washing machine is used to fill the tub with cold, warm or hot water for the wash and rinse cycles. The valve is operated by electric solenoids that are controlled by the timer or electronic control board and the water level control/water level selector switch or pressure switch. If your washer continues to fill during a cycle, the water inlet valve could be at fault. To verify that the valve is at fault, unplug the washer when the symptom occurs. If the washer continues to fill, then the water inlet valve is defective. If the washer stops filling, then the problem is related to the electrical circuit that controls the valve. The water level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak or is plugged, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill.
To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level pressure switch may be defective. Inspect the switch for signs of a mechanical defect or debris plugging the hole in the inlet nipple. To test the switch contacts for continuity with a multi-meter, you will need to apply the proper amount of air pressure to the air dome tube and then look for the switch to go open circuit at that level. The easiest way to do this is to start the washer and allow it to fill to the normal level and then remove the power cord. Locate the pressure switch and remove the wires from the correct terminals and then perform the continuity test. There should be infinite resistance or an "open circuit" when the water level is correct. If not, then the switch is defectiv
Jan 11, 2017 | Cars & Trucks
How do I stop the water from over filling
check the small tube from the bowl up to the water level sensor
check the water sensor is operational
check /replace the water control solenoid valve
it works like this
as the water flows into the bowl
it rises and that increases the pressure on a diaphragm in the water level switch buy means of the small tube
when that pressure is equal to the water level setting ( small , medium , large ) it overcomes the spring setting and breaks the circuit to the water solenoid valve which turns off . at the same time the pressure switch progresses the program to start the wash
Oct 07, 2016 | Haier Washing Machines
My dryer had no water going into the container
Not Filling With Water OTHER washers test similiarly- test water inlet valve water and pressure switch. Test the water pressure level switch a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
# Test procedures to follow
* Disconnect the washer from the wall outlet
* Set the timer dial on regular and pull the knob to turn the timer push-pull switch on
* Set the temperature switch to the cold/cold setting
* Open the controls panel to gain access to the water mixing valve solenoids
* Touch the 2 terminals on the cold water solenoid with your volt meter test proves. Make sure that your body don't touch the washer cabinet, this eliminate the chance of getting an electrical shock.
* Have someone plug the washer cord for you while you check the voltage
* The reading should be 120 volts
* Touch the 2 terminals on the hot water solenoid with your volt meter test proves. Remember, to keep your body from touching the washer cabinet to eliminate the chance of getting an electrical shock
Have your helper plug in the washer cord again so you could check the voltage at the hot water solenoid
The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the washer is not filling, the problem should be on the water valve, the screen filters or the water supply
If one of the solenoids is bad you will need to replace the complete water mixing valve assembly YOU SHOULD ALSO GET AN OHMS READING OR SHOW CONTINUITY WHEN TESTED UNPLUGGED ON BOTH SELINOIDS HOT AND COLD
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
Jan 16, 2016 | Dryers
Service manual? 22 yrs old ...pump works but no water
How to Check a Ge/Hotpoint Washer when Is Not Filling With Water OTHER washers test similiarly- test water inlet valve water and pressure switch. Test the water pressure level switch a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
# Test procedures to follow when a GE Hotpoint washer is not filling
If the GE Hotpoint washer is not filling, the problem should be on the water valve, the screen filters or the water supply
May 05, 2015 | Washing Machines
No water going in washer
How to Check a Ge/Hotpoint Washer when Is Not Filling With Water OTHER washers test similiarly The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
* The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
Apr 02, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Does not stop filling up
Every washer has a water level switch. These switches work by air pressure. As water rises in the tub, air trapped in the pressure tube on bottom of the tub is squeezed till it makes a lever inside the water level switch kill the power to them water valve solenoids and shift the power over to the motor. Sand and sediment will get into the sump where that tube connects blocking the air and so the switch dont know when to shut off. Disconnect the hose at the water level switch and blow out the stuff on bottom of tub. Reconnect the tube securely and pump out any water in the tub. Restart the machine.
SOME REPAIR PIX
Dec 20, 2009 | Washing Machines
My washer will not fill with water
The first thing to check is the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the opening on the water inlet valve and make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Test for continuity. A lack of continuity will mean a bad solenoid and the valve will need replaced.
If the inlet valve checks out alright, then the next place to look would be a malfunctioning water level/pressure switch. It is a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. Make sure there are no obstructions in or damage to the plastic tube. The switch can be tested for continuity in the same manner as the water inlet valve solenoids. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Mar 18, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
