Just stopped working
Checked fuse
    Top Expert:
  • Heating & Co... Master
  • 48,512 Answers
Google make/model manual
Posted on Mar 29, 2015
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
The rear defrost stopped working, and i dont even know where to begin to try and figure out why its not working
Check for burned fuse on fuse box
On the owner manual you ll find the location of the fuse on fuse box and how to check for burned fuse
Feb 04, 2013 | 2008 Chevrolet TrailBlazer LT
2 out of 3 brake lights dont work
If any light lights up when you apply brakes, then the brake switch is ok. The problem could be a fuse and/or a relay. or the bulbs. Those bulbs are dual filament so one filament could be bad, for stop or tail lights.
Oct 02, 2012 | 2002 GMC Envoy XL
2000 Mercury Sable Cruise Control stopped working
Check the fuse panel. Look for a fuse that says cruise on it. If you cant find a fuse for that check your cigarette lighter fuse. somtimes they are conected. Its going to be something simple like that.
Jun 11, 2012 | 2000 Mercury Sable
Suddenly my radio and clock stop working, it was working for few day after it stopped working but again stopped working.
You could have a short some where in the wiring. If its an aftermarket radio see if you can pull it out and check to be sure all wires are properly done.
If its a stock radio then check the fuse panel!
Mar 03, 2011 | 2005 Honda Accord
I have a 1992 Toyota Camry and all of a sudden my A.C. stopped working and also my power windows, spedometer, rpm's gas gage- all stopped working. which fuse is it?
there is a fuse for each unit, so check fuse box connections as more than one unit has stopped,,check wire harnnes in dash
Jun 30, 2010 | 1992 Toyota Camry V6
03 ford explorer cruise control stopped working
If I don't remember bad, check the position 15, fuse 15AMP (mini fuse) underdash fuse panel.
Hope solve your problem (remember rated this help).
Feb 19, 2010 | Ford Explorer Cars & Trucks
Radio just stopped working
Check the fuse box under the hood. It should be located on the drivers side. Open it up and check around for the radio fuse. Most likely labeled as "ACC" which is short for accessorie. It should be a 15 AMP fuse. Last winter my radio blew out as well and I check the fuse box and replaced the fuse and now it works fine. The fuse was burnt beyond believe though. If you havent already fixed the problem I hope this helps.
Apr 24, 2009 | 2001 Dodge Caravan
2003 silverado 1500 v-6 brake lights dont work
ljones, Did you check the "VEH stop" fuse in the left side instrument panel fuse box. There are 3 stop light fuses, 1 for all the stop lights located in the under hood fuse box. 2 in the left side IP fuse box. 1 for the upper stop light and 1 for the lower stop lights. The fuse box in the IP is where the upper and lower stop lights split. Let me know.
Feb 26, 2009 | 2003 Chevrolet Silverado 1500
My 95 civic ex coupe automatic help
could be fuse try pulling each fuse one at a time and checking for a blown fuse just put each fuse back after u check it
Jun 20, 2008 | 1995 Honda Civic
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
