Question about LG Washing Machines
My drum keeps filling with water when water turned off and appliance off. If the door is open it fills to the bottom of the door, if the door is closed it fills right up. I don't know where the water is coming from. All filters are cleaned. New drainage hose attached. No error codes. I can still use the machine. It just gets a mind of its own when it's not in use. What is going on? Please help. I have had to totally disconnect from power and water. Model WD1435RD lg washer/dryer combo.
    Top Expert:
  • LG Master
  • 42,778 Answers
Check and replace the water inlet valve . and turning off the spigot is not a bad idea when not using the machine
Posted on Mar 29, 2015
jgwhomeequip
  • 1902 Answers
SOURCE: Even when not programmed to the washer/dryer fills up with water?
Check the water inlet valves, located where the water lines plug into the machine. Also check for proper water pressure and make sure that your water pressure is not surging. If this help please rate. Thank you
Posted on Feb 12, 2009
  • 13 Answers
SOURCE: water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Posted on Apr 11, 2009
  • 714 Answers
SOURCE: Older model washer, water coming out under the washer
hose could be leaking going to your pump there are two attached to it, also the pump has a seal where it connects to the motor could be leaking there, and there is a tub seal. but it does sound like a hose came loose
Posted on Feb 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: LG Washer/Dryer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
  • 57 Answers
SOURCE: I have a Bosch nexxt
Check for voltage to the water valve when starting wash cycle. If no voltage replace main control.
Posted on Jun 03, 2011
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
Fills when not being used
where the water pipes plugs into machine it has a water stop valve there. turn water off at mains and unscrew pipe. it may have a blockage of some sort keepng the valve open. hope this helps
Feb 14, 2012 | Hotpoint First Edition WMA22 Front Load...
Dishwasher not filling
The water float switch, located on the inside bottom of the machine, may be stuck in the up(off) position keeping the water valve from functioning. This is a safety device that turns the water valve off when the machine fills in order to keep it from overflowing.
The water inlet solenoid mounted on the inlet valve under the bottom front may also be malfunctioning not allowing the water valve to open and fill the machine. If electricity is present at the solenoid terminals when the machine is in fill cycle, then check the solenoid coil to see if it is open(no continuity). Also, the timer may not be calling for water/ sending voltage to the inlet valve solenoid.
I would start by manually operating the water float valve a few time to see if that helps. You should hear a microswitch click each time the valve stem is moved up or down by the float. If not, check to see if voltage is getting to the float switch and the water inlet valve solenoid.
Most(if not all) machines have a safety cutoff switch which activates when the door is opened. That switch could also be malfunctioning not allowing voltage to the water inlet valve solenoid in fill cycle.
Jan 26, 2012 | Meiko Dishwashers
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks
I had similar issue. Fill tube running from the bottom of detergent tray to the washer drum was plugged.... (by a sock!!!). How did it get there? I'll tell you. You see the drum seal (around the inside of the door) is not a tight seal. You can actually reach up behind it from where it meets the top of the drum. Anyway in my case, a sock made it's way through that seal and outside the drum and into the drum containment vessel. So when the drum spun (to dry the clothes and empty the water) it made a terrible noise. The sock became lodged at the base of the fill tube opening and plugged it thus not allowing any water into the drum. Instead, when filling, the water just flowed out from the bottom of the detergent tray and onto the floor. I hope this helps.
Jan 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Washer fills but won't agitate., just keeps draining a bit and refilling
Check your top door safety switch, this is usually the problem when the washer fills and then nothing. You will see a small plastic bar on the bottom side of the door. This bar goes thru a hole at the base of the drum (upper panel) which in turn depresses a switch. Check to see if this is working properly.
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
