Question about Campbell Hausfeld Extreme Contractor Series Air Compressor
Compressor builds to 100 lb pressure. after a few minutes use, it comes on again to begin pressure build up. next cycle, it trips circuit breaker in house.
Let the compressor cool for approx. 15 minutes and it will fill one time. Next cycle, it trips breaker again.
    New Friend:
  • 29 Answers
You didn't provide all pertinent info available to you. Lets take what we have; and, consider why your compressor is overloading the circuit breaker. Points to ponder:
  1. Not knowing the exact model (not series) I don't know what the amperage pull is for your "extreme" compressor or the circuit breaker's rating. A 25 amp compressor connected to a 25 amp breaker could be an issue. Campbell Hausfeld's support pages are crashing so I can't check the possabilites.
  2. Are you using a lightweight extension cord? The lower the rating of an extension cord the higher the amp pull on the breaker. If you eliminate the extension cord does the problem go away? Ohm's Law applies. <http://www.ohmslawcalculator.com/ohms-law-calculator>
  3. What else is on this breaker? Is there other high-amp equipment in another room (water cooler, window air-conditioner, portable electric heater, etc.) pulling from this same circuit breaker.
  4. Is the circuit breaker not performing to specification? I've seen failing breakers trip early.
    First, check the owner's manual for power requirements. Next step, use no extension cord; and, insure nothing else is pulling power on that breaker. Then, use a different breaker and see if the problem follows the compressor. If all else checks out than I'd consider binding in the compressor causing the amp pull to be too high.
    Good Luck!
Posted on Mar 29, 2015
    Master:
  • 507 Answers
Look at your motor amps and voltage settings. Any extension cord used should be capable of delivering full power required by the motor full load amps rating.
Extension cords should be oversized in wire gage or ampere rating to avoid voltage drops. If this is not the issue, then the house wiring splices and connections needs inspecting for tight connections, start at the breaker panel, the receptacle outlet, then in between.
Posted on Apr 03, 2015
It turns on and builds pressure but at times stops because the circut breaker for my house trips off.
if the house circuit breaker trips ,it indicates an excessive current draw for the machine
could be a faulty start / run capacitor or partially failed motor.
have an electrician check it out
May 31, 2015 | Air Tools & Compressors
Circuit breaker trips after water supply cycle
check the condensor fan in the compressor area and make sure its running if not the compressor will overheat causing high head pressures on the compressor causing it to draw too much current to operate the compressor and kick the breaker out,also make sure the condenser coils there are clean and it has ample air movement away from the wall
Apr 21, 2013 | Kitchen Appliances - Others
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a porter cale C5101 compressor. It hesitate to auto start when the pressure is low, always trip my circuit breaker.
What amp breaker do you have this hooked to. I would use no less than 15 amp ,preferrably a 20 amp. Next do you drain tank after use on a regular basis. If you don't moisture can build up inside tank and cause hard starting on automatic. If you need to drain tank there should be a drain valve on bottom of tank. try turning it counterclocwise with compressor off. If it dosen't turn that way try clockwise,air and moisture should drain. If you have alot of water in tank then shut valve and turn compressor on and bring to full pressure,then repeat draining procedure until no more water comes out. Hope this helps. Thank you
Nov 12, 2010 | Porter Cable - Cable C5101 Oil Free...
My compressor suddenly quit cycling what went wrong?
hi there!
there are several factor on cycling failure, most common on it is the pressure switch device,checking on this,plug out or switch off main circuit breaker for compressor, disconnect pressure switch if this is a single phase connection,there are two supply wire coming in and two wire coming out on pressure switch.direct connection of compressor motor on power supply to test if it is cycling manually,after direct connection of motor compressor to power supply w/out pressure switch,switch on for 5 to 10 minutes o build a low [pressure then swict off again,then switch on again even there is a low pressure observe if there is cycling motor running if this done replace pressure switch.if still have same problem motor tripping another case not to cycle bring this to electric motor service center.have a nice day dont forget to fix my rate.
May 07, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
My compressor runs fine until it gets to about 100 psi. It then sounds like it labors hard, and then blows the circuit breaker. Any suggestions? It is a Crafstman 6 hp,k 30 gal, 150psi max single cylinder...
Never assume anything; check your pressure guage to make sure it is reading correctly. If a guage gets faulty, it could be showing less pressure than before, but everything else is the same, therefore the pressure is the same as always but the guage says different. If guage is good and 100 lb shows just as there is 100 lb in the tank, then maybe your electric line is not sufficient capacity and the motor starts to labor because it is pulling more energy than the line can produce and therefore everything heats up and the breaker pops. Have you moved the compressor or had a need to change the electric line and maybe it is too long or toosmall to handle what it did in the past ? Or, maybe the motor windings are old and getting deteriorated, thus allowing the motor to lose power and without the extra power to fight the pressure as it builds, the motor and line strain to work, and the breaker pops. Or, maybe the inlet and outlet valves on the head are weak and cannot hold the pressure in check as it builds in the tank thereby forcing the motor to work even harder against the pressure it already built-up; in this case, the head needs to be removed and new valves and springs replaced. Most compressor companies offer a valve kit just for this purpose. Goodluck, Macgvior
Jan 31, 2010 | Air Tools & Compressors
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Campbell Hausfeld Extreme Contractor Series Air Compressor Logo
275 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
