On starting the machine water is continously running out.
  • Washing Mach... Master
  • 5,323 Answers
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
By the way my advice is free cuz God is good!
on starting the machine water is continously runni - starting-machine-water-continously-fgv1ctnzjgewe3hu2qpqylbk-3-0.jpg
starting-machine-water-continously-fgv1ctnzjgewe3hu2qpqylbk-on starting the machine water is continously runni - starting-machine-water-continously-fgv1ctnzjgewe3hu2qpqylbk-3-9.jpget/uploads/images/starting-machine-water-continously-fgv1ctnzjgewe3hu2qpqylbk-3-9.jpg
Posted on May 08, 2015
INDICATING h2O CONTINEOUSLY draining water
h2o is the chemical symbol for water. But if the water keeps running and does not stop, even when the machine is full it could be the machine has a defect level indicator, or the water lock does not work. When the lock even don't closes what you remove the power the lock is defect.
Mar 24, 2015 | Ariston Technologies Washing Machines
Keirig machine makes noise while power is off
Needs factory service. Call 1-866-901 2739
Jul 18, 2012 | Keurig B60 Coffee Maker
Machine water pump continously running on power
problem more than likely faulty triac in electronic board solution : replace motor control board
Feb 25, 2010 | Fisher and Paykel Fisher & Paykel Washer
Hot water running continously
If your FAV6800AW/FAV9800AW has water flowing water with the power off or water fill cycle has ended then your water valve is stuck open. I’m sure crud in the valve seats preventing the washer water valve from seating. The water valves are sealed units and need to be replaced. I Haven’t had to replace yet but I will post links to the SM and parts replacement link. See this post for possible issue with a new substitute 12002242 part replacement.
The Service Manual for reference. Sears Parts Direct for reference.
Appliance Zone AZ
Sears Parts Direct old p/n 25001001 new p/n 12002242
May 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hot water won't stop running
It is the hot inlet valve that is the problem. replace it and that should solve the problem.Plz rate my solution.
Thanks.
Jan 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water continues to fill machine but the wash cycle never begins
The pressure switch is stuck and not sensing the correct amount of water
Aug 04, 2008 | Washing Machines
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
u will need to replace the water solenoid that is letting the water in it is a fault that does occur with all solenoids,theses are were the water pipes connect to
Sep 10, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
