Question about Home
I painted some copper pipes in an outdoor shower block (campsite) last year but they have now turned green. What can I do?
    New Friend:
  • 30 Answers
The copper has oxidised. Lightly rub it down with wire wool. Then put on a clear lacquer
Posted on Apr 02, 2015
  • 3,382 Answers
Enjoy the colors, that is normal.
How can I deep-clean or spruce up the white Dangari resin arm chairs?
Try using Zep shower cleaner..Wet the chairs, spray it on and let it sit for ten minutes and wash it off with a pressure washer. Paint is not going to stick for very long on resin.
May 19, 2014 | Evolutif Dangari Resin Outdoor Dining Arm...
Changes in amount of water flow from shower head
when he soldered the connections on these pipes.. he may have partially blocked the flow with solder inside..if its restricted up to 50% then its a hell of a pressure loss..hot water is always lower in pressure anyway..also take the shower head and dunk in a clr solution it may have calcium deposits inside the small plastic orafices in it..
Jan 12, 2014 | Water Heaters
Can i flush my water pipes out using bicarbonate soda ,from the mains supply to my house,as i have blue green stains in shower ,basin ,toilet ,a blood test shows a copper reading of 23.1, in bloodstream ,...
Flushing pipes won't help this problem at all. What you're seeing is electrolysis, caused by galvanized pipes connected to copper pipes. A tiny electrical current (like a little battery) is created that causes copper molecules to corrode from the inside of the copper piping. You need to install an electrolytic union (breaks the electrical connection between the galvanized and the copper) at each of those connections. This must have started after some plumbing was done where copper was used to replace galvanized. That's the place to look and that's where you'll find this problem. Do this soon -- the blue/green stains are copper that's been corroded from the inside of your copper piping which will soon start leaking as a result. This could also happen at a water heater, which should have an electrolytic union at EACH connection (Hot, Cold and Drain if there's a recirc. system). Don't let someone tell you a brass fitting does the same thing -- that's an old plumber's wives tale that isn't true. Google Electrolytic Union to see what the fitting looks like.
Feb 19, 2018 | Home
Customer has had grill since 2008 and the pipes where gas comes in has rusted and broken down
I suspect, the piping that was used originally used for the incoming has line was not Black Iron Pipe as required. It was probably galvanized pipe instead. Which, has never, ever been approved for gas delivery piping. Even under the worse conditions, unpainted Black Iron Pipe would not have rusted thru in just 3 years.
Solution: Replace all of the existing gas piping with either Black Iron Pipe (paint it after installation), Flexible Copper Tubing (requires no paint) or Flexible, Stainless Steel, Vinyl Coated Pipe. The piping diameter should be a minimum of 1/2" OD.
If this is not a built-in grill (i.e. Outdoor Kitchen) and is still a cart grill. Code requires that there not only be an accessible gas line shut off valve within 3' feet of the grill. But, from that point on to the grill, it must have a 12' long rubber, quick disconnect, gas hose.
Hope this helped you. Please let be know.
Jun 16, 2011 | Brinkmann Charmglow 810-7600-S Grill
Jsut installed a tuscany Asti Tub and Shower Faucet, when the mixer handle is centered and you are running thru tub spout, water still comes out of shower pipe. it does not do this if solely set to hot or...
Check the valve body to make sure it is right side up. there will be a marking on the valve that tells witch is to go to the tub spout and witch to the shower head. If you have it right then you will need to disassemble the valve body and look for debris in the cartridge.
Feb 11, 2011 | Ldr Industries Home
Shower runs much cooler in winter this is the third go one we have had in the last 10 years all reacting the same way
Hi, going off a previous problem with my shower being colder in winter i found a simple solution. The copper water supply pipes in my house were not insulated and in the colder air that made a dramatic difference in temperature with the hot water being cooler and also because of the much cooler water from the cold supply going into the shower mixer. Please have a look to see if your pipes are all well insulated.
Jan 11, 2011 | Home
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Do you have written instructions for taking out an old faucet and replacing it with the INS898D-3/09 faucet? The directions that came with are just pictures and I need more explanation.
Good for you taking on this project. The first thing I will start with, is if you are not comfortable soldering copper then I would stop and call in a plumber to install the shower. If you have soldered copper in the past and are comfortable doing so then please proceed. Give yourself 2 to 3 full days to complete the project. You will need: Plumbing permit, available from your local munucipality. It will need to be inspected after the work is completed. Solder, solder flux and propane torch Heavy suede work gloves Water Spray bottle Pipe wrench Safety Glasses Hacksaw Deburring tool for copper pipe Emery cloth Tape measure Screw driver or screw gun Mounting Screws Old blankets 5 gallon pail 1/2" Copper pipe and fittings To begin we will have to uninstall the old shower. I find it helps to take photographs of the existing system so that you can see how the new one should go back together in case you get stuck halfway through the project and cannot see how to finish it off correctly. If you can access the shower from the other side of the wall, great. If not you will need to remove the shower surround or tile on the end wall where the plumbing is. Be sure to protect the tub with an old comforter or something to keep the tub from getting scratched up during construction. Before removing the old shower be sure to locate the shut off valves and close them. Turn both hot and cold on in the shower to remove any water pressure in the lines. Disassemble all the trim pieces of the old shower including the tub spout, handles, diverter and shower head. Take measurements of the existing piping to assist you when it comes time to cut and assemble the new copper. Do not reuse any of the old fittings. They will be very difficult to solder and new ones are very cheap. You should have 2 copper risers coming out of the floor, one cold, one hot. Cut them approx 12" above the floor. Repeat the same process for the tub spout and the shower riser. With all 4 pipes cut you can now remove the brass manifold from the 2X4 blocking. Disassemble the shower flange pipe from the copper shower riser. You should now have just the cut copper risers coming out of the floor. Use the deburring tool to clean the sharp edges where you cut the risers. This will aid in soldering the new pipe in and avoid you cutting yourself on the sharp copper while you work. To be continued.
Now that everything is apart it is time to cut all the copper to proper size and mount the brass manifold on the blocking within the wall. Take a close look at the drawings on the instructions. The plastic piece that covers the brass manifold will need to be flush with the drywall so that when you install the escutcheon plate it is also flush with the drywall. Be sure to test fit all the plumbing before soldering to ensure. begin by soldering the fittings that will screw into the manifold. Once this is done begin reconnecting the plumbing system. Again I can't stress enough that if you are not comfortable or have experience soldering copper to bring in a licensed pro. Nothing worse than completing the job and finding its either not up to code or worse leaks and you have to back over the job. Good luck with your project and let me know if I can be of any further help. Sorry it took so long to finish this. I was out sick for about a week right after I completed the first part. Good luck.
Aug 03, 2010 | Moen & One Handle Tub & Shower Faucet
When installing a shower temperature control valve should the cartridge be removed before soldering to copper pipes
Yes you need to remove the valve befor you solder the copper pipes on it. If you do not remove the valve you will melt it to the valve body and then it will not be useable.
Mar 02, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
101 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
