Question about Cameras
Battery stuck in camera (swollen)- managed to remove but no response at all after replacing with fully charged spare battery
  • 28 Answers
Dear!
At your home you can use vinegar (citric acid would be better due to chemically more active ) with a cotton swabs. But you must clean out as clean as possible with rubbing alcohol. Because the remaining vinegar will be corrosive. Again You can sometime clean out with rubbing alcohol again and again the rest of the vinegar.
Hope You Luck! A Professional Camera Clinic Guy!
Posted on Mar 31, 2015
Testimonial: "Thank you. I will try that too. The compartment is very small and not easy to see inside."
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Please also clean the battery contacts in the camera. Try this with a dry cloth or cotton swabs. When the oxide is difficult to remove, use a little electric contact oil, but make sure you remove it complete, because these oils work coisive in th long run.
Posted on Mar 29, 2015
  • 8 more comments
  • Anneliese Simpson
    Anneliese Simpson Mar 29, 2015
    Contact oil? WD40? Will that do it?
  • Harrie Mar 29, 2015
    To see what I mean, put this in Google and press images.https://www.google.nl/search?q=contact+s...
  • Anneliese Simpson
    Thank you. :) WD40 is there.
    Let us know if it works. I'm a bit curious from nature.
    by nature. It is always difficult when you try to communicate in a different language than the one your motor learned you.
    Mother.
  • Anneliese Simpson
    You're perfectly understandable. I wouldn't be. :)
  • Anneliese Simpson
    Anneliese Simpson Mar 30, 2015
    Didn't work, I'm afraid. :( It's dead.
  • Harrie Mar 30, 2015
    You cant see what is coroded inside, nor what the presure from the swolen battery did. Sorry
  • Anneliese Simpson
    Thank you for trying to help. :-D
Nikon d300s
Refer to everything that has to do with battery. I wonder if you can see anything on the control panel. If nothing is there you battery is dead for sure.
If you can see symbols on the control panel, it could be your on on / off switch is defect.
The Battery
Check the battery level be focusing the camera and replace or charge the battery if necessary. Do not continue charging once the battery is fully charged as this will result in reduced battery performance. Whenever possible, carry a fully charged spare battery when taking pictures on important occasions.
Do not use the battery at ambient temperatures below 0 C (32 F) or above 40 C (104 F).
Charge the battery indoors with an ambient temperature of 5 C to 35 C (41 F to 95 F) before use.
Note that the battery may become hot during use; wait for the battery to cool before charging.
Failure to observe these precautions could damage the battery, impair its performance, or prevent it from charging normally.
On cold days, the capacity of batteries tends to decrease. Be sure that the battery is fully charged before heading outside to take pictures in cold weather. Keep spare batteries in a warm place and exchange as necessary. Once warmed, a cold battery may recover some of its charge.
Dirt on the battery terminals can prevent the camera from functioning. Should the battery terminals become dirty, wipe them off with a clean, dry cloth before use.
If the battery will not be used for some time, insert it in the camera and completely exhaust it before removing it for storage. The battery should be stored in a cool location with an ambient temperature of 15 C to 25 C (59 F to 77 F). Do not store the battery in hot or extremely cold locations.
Nov 16, 2013 | Nikon Cameras
My nikon s4100 coolpix does not turn on
Hello Ice,
Please check the battery of the Nikon Coolpix 4100 Digital Camera. Please check the battery is fully charged or may be its damaged if its swollen. Also check the contact points of battery and camera and clean it. Insert the battery and charge it fully. When the battery gets charged fully then press the power button 4 to 5 times to start it. If the battery is damaged then replace the battery with new battery.
Jul 04, 2011 | Nikon Coolpix 4100 Digital Camera
I have a Cannon EOS 30D. There is no response whatsoever when the power switch is turned on. I have tried 2 separate fully charged batteries with no change in the problem. Can you help me? ...
There is a small Lithium coin battery on the side of the battery compartment that is the memory battery for the camera functions. Remove the battery pack first, then holding the camera with the lens facing your body look at the top back ledge of the battery compartment and see lettering CR2016. slide your finger down the back ledge and feel the ridges. with slight pressure slide the compartment up and take out the CR lithium coin battery. replace with a like new battery. If you ever need to reset a stuck program in the camera, remove this battery for a few minutes and the camera will re-boot to factory settings. This battery last for about 5 years.
Sep 19, 2010 | Canon EOS 30D Body Only Digital Camera
Every time I change the battery in my pentax s5i the time and date revert to' as new' and I have to reset date and time. I have been using the camera for 6 years without this problem. Any ideas?
It may be a circuit designed to maintain date/time settings when the battery is removed that has failed.
Although a very good camera, I would imagine the cost of repair would be greater than the value of the camera.
A couple of thoughts though, if you are making an immediate swap with a charged spare battery, then there's a fault, you may find a firmware upgrade on the Pentax website which may help.
If there is a delay in replacing the battery, then having a spare, fully charged battery available at the time, may circumvent the problem.
Sep 06, 2010 | Pentax Optio S5i Digital Camera
When i zoom in it turns black
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a new cable. This camera is no longer repaired due t oshortage of spare parts. In order to organise your Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 11, 2009 | Kodak EasyShare V570 Digital Camera
THE LEN IS STUCK ON EXTENDED POSITION AND WILL NOT RETRACT TO THE OFF POSITION? BATTERY WAS FULLY CHARGE.
If no power on the camera:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Turn on your camera without the memory card.
If there is power on the camera, bnut the lens is stuck:
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
Dec 10, 2009 | Kodak EasyShare DX7630 Digital Camera
When I load fully charged batteries it comes up with the 'battery low' warning and sometimes 'zoom error'
Believe it or not, the batteries are not fully charged.
1. Use alkyline batteries to test if camera is ok.
2. Carry a spare set of alkyline batteries
3. Don't mix battery types or mA sizes
Sep 01, 2009 | Olympus SP-310 Digital Camera
W380 goes blank when connecting via usb in files transfer mode
Finally I got it to work. I had to fully charge my battery as I had noticed that when i was trying before the computer was trying to charge the battery. Once I had fully charged the battery and then attatched it to the computer put it into file transfer mode it was really easy. Anyway I hope you have managed to solve your problem.
Nov 20, 2008 | Sony Ericsson W380i Cellular Phone
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Cameras Logo
61 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
