Question about Sony 7.2 Channel 4K Black A/V Receiver - STR-DN1050
Hi There, I just installed the SONY STR DN1050 AV receiver but I'm facing a couple of problems. - when I switch from TV to DVD, the sound falls away for a couple of seconds. - I have an old analog LP-player with analog input but I have to put the volume of the receiver to max to hear anything, which is not handy.with my previous amp (also a sony) I did not this problem. - there's also a function for a second zone, but this seems not to work. Thanks for your support. grts, P
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
SOURCE: Sony STR-K660P Intermittent sound problem
xdfcbzdf
Posted on Mar 13, 2008
  • 16 Answers
SOURCE: sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
Posted on May 09, 2008
The Machine
  • 788 Answers
SOURCE: Protection Problem with Sony STR-DB780 AV Amp / Sony SA-VE535HS speakers
How have you checked for shorts in your wires? Did you use a multimeter? Test the resistance of your new wires compared to the old wire, should be close to the same and next to nil on the same wire but if you don't get infinity between pairs then you have a short.
About your second problem, what kind of connection are you using for your TV sound? Sounds like it's a digital connection but is it coax or optical? Sounds as if it loses sync with your signal and has to resync. If you are using optical you may have a bad cable if you are using coax the cable may be picking up interference from something or the cable may be bad.
Posted on May 22, 2008
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
Tune stations on the radio
Use this link to see how to set up and listen to AM/FM stations.
How to listen to FM and AM broadcasts
Dec 18, 2014 | Sony 7.2 Channel 4K Black A/V Receiver -...
Sony STR-DG1000 HDMI video not displayed
That's strange, does the monitor work with regular av cables or and s-video cable ?
Dec 27, 2007 | Sony STR-DG1000 7.1 Channels Receiver
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Apr 02, 2017 | Sony Str-k750p Av Reveiver
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
Unable to hear dvd audio when dvd playing on Sony STR-DE575
Hi The first thing to do is disconnect the red and white audio cables from the back of the receiver, and plug them directly into the tv. If you then have sound from the DVD, then you have eliminated the possability of no audio coming out of the DVD player. If the DVD player checks out fine, then I would try plugging the jacks into another aux input on the receiver, and select that and see what happens. Also, if there is a "tape monitor" button on your Sony, make sure it is turned off. I'll assume the receiver has sound from other functions, so it would be rare for one of the inputs to just stop working, (but certainly not impossible), I'm not familiar with that model, and normally I would say it could just be a dirty selector switch, but since you mentioned having a remote, then switching between inputs is done by the microprocessor, not a physical switch, so if you cannnot get sound through using another input, then it could be expensive to repair. Hope this helps, and good luck!
Apr 30, 2007 | Sony STR-DE575 Receiver
Sony 7.2 Channel 4K Black A/V Receiver - STR-DN1050 Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
