Question about Zanussi Ovens
Door falling off ZCG662gXC Zanussi gas double oven
Pins keep falling out of hinges
  • Joh Wright jones
    Joh Wright jones Mar 31, 2015
    The hinges consist of pins top & bottom which pop out!
SOURCE: oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
Posted on Feb 08, 2009
SOURCE: oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Posted on Feb 28, 2009
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Kenmore oven door fails to lock
1. Remove the pan drawer
2. With someone holding glass up, remove the four screws at the bottom of the door that hold the glass front to the door frame. Gently lower the panel about two inches until the side guides are below the door trim cap. Place out of the way so it doesn't fall over etc.
3. Keeping the door closed, use a spring puller to remove each spring from the hinge. (I made one out of a hanger and a screwdriver. Double thickness at the hook, wrapped and secured around the screwdriver to make a handle) If you do things this way be VERY careful. Be sure it is really strong and is not going to slip. The springs are really under tension and will shrink down about an inch from where they are hooked. (Be sure to support the door so it does not fall open when the springs are removed. It will just make things worse.)
4. After the springs are off gently open the door all of the way.
5. Pull down the hinge locks from the oven body and lift the base of the door up. This will lift the door hinges off of the mounts in the oven frame and allow you to pull the door away from the body.
6. Place the door on your box or workbench etc
7. Remove the two screws on each side of the door that hold the hinges in place. Remove the hinges.
Reinstallation is in reverse.
Hinge repair.
By placing the lower part of the hinge (by the axle) against a ruler I was able to see that the upper section was bent out on each hinge. To correct it I placed the hinge over a pair of 4x4 blocks so that it curved up in the center, and hit it a few times with a hammer. The metal was very responsive and quickly bent back into shape. Be careful here as you don't want to bend them too far. I actually went a little past true, wanting to get a little more push at the top of the door. I placed the hinges directly on the oven to see the difference and they looked good (Be sure to put a piece of cardboard or rag between them and the top to keep them from scratching the surface.
Put the hinges back in the door, screw it together and hang it back on the stove, replace the springs and the glass, and check your fit. Good luck.
Feb 01, 2013 | Kenmore Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Oven door zbf360x zanussi
Feb 14, 2009 | Zanussi ZBF360X Electric Single Oven
Oven door falling down on the Frigidaire stove
Try to replace the hinges the locking mechanism is going out
Feb 08, 2009 | Stoves 720EF Electric Double Oven
Main oven door does not shut properly
i removed the side panels which exposed the hinge mechanism. I have then removed the whole door and the associated hinges by simply unclipping the retaining springs.
Dismantling has revealed that the pivot pins have become dislodged from their housing, and this is why the door was not shutting properly. I am now spot welding the pins back into position.
Also noted is wear in the slots in which the pins rotate but am hoping that it is all still serviceable as I think spares for Stoves are expensive.
One other point to note is the very poor design of the whole hinge assembly. Not what I expected from Stoves.
Jul 31, 2008 | Stoves 720EF Electric Double Oven
Dacor Gas wall oven
is there tension on the door at the point where it doesnt seal,is the spring broken/missing,when the door opens and closes is there enough travel from point a to point b inside the cabinet on both sides of the hinge area, is the sping loaded mechanism damaged .
Dec 30, 2007 | Ovens
Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Jul 01, 2007 | Zanussi ZBQ365 Electric Single Oven
Ovens Logo
106 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
