Question about ZTE Cell Phones
How do I open slot for SD MOUNT UN MOUNT. I see two slots on each sides (right & left) with small holes on ends of slots. I don't want to damage the slot covers or mount slots. It's not like other slo
How do I open slot for SD MOUNT UN MOUNT. I see two slots on each sides (right & left) with small holes on ends of slots. I don't want to damage the slot covers or mount slots. It's not like other slots that flip out cover and expose internal slot. Also, how do you open to expose battery. It's a ZTE Model Z970 4.4.2 Android Version
nicholaschum
  • 55 Answers
SOURCE: memory card slot
The solution to this problem is, it will not break because the first time I tried opening the memory card slot, it won't come off. So I just put my nail in the hole and flicked it up hard. The memory card slot will not break that easily. Hope this works!
Posted on Aug 30, 2007
SOURCE: cant find micro sd slot
take off the battery cover, its on the right side, underneath the chrome trim
Posted on Aug 09, 2009
SOURCE: Razr V3 left hinge is loose. How do you tighten/replace?
http://www.themotoguide.com/razrdisassembly.php
Posted on Nov 10, 2009
  • 821 Answers
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Posted on Apr 16, 2010
SOURCE: I have a motorola xprt. It has a micro SD slot and another slot that I thought was SD. What is it?
The other slot is your SIM Card
Posted on Aug 10, 2012
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
SD Card and disc stuck in CD slot of Alienware M14x?
try taking a small piece of wire and bending a small hook into one end slide it in on TOP of the stuck disc and hooking the center hole of the disc, (you don't want to get the wire under the disc because you could damage the disc reading hardware) also once you have the disk hooked you may have to use the tweezers to gently hold the front of the disc up to align with the slot as your pulling it out. you should feel a little resistance but don't try to force the disc out too hard.
Mar 23, 2015 | Dell Alienware M14x Notebook
How replace trunk lid torsion bar 2005 malibu
There are two rods, one has rubber on it. I just replaced the one with rubber on it. Looking at the one rod that was still in place, you can see it mirrors the rod you are going to replace, the placement is just opposite the one that is in there. The rod has a left end that is a square "C" shape, and the right end has a "V" bend right before the end. First position the rod above the seat release cables (if you have them) then position the "V" end near the inside right top of the trunk. Then slide the left "C" end into one of the three slots (I used the bottom slot). Leave it loose so it can rotate with just the tip in the slot. Slide the rod to the right so the "V" is above the spring clip (don't clip it in yet). The right side and the left side of the "V" has to fit into the tabs underneath and inside the top of the trunk. Compare to the left side to see how it fits. Once in place, you can then lower the "V" down to the clip and snap it over the bottom tip of the "V". These steps are easier if the trunk is propped not fully open. I had someone lower the trunk part way while I lay on my back inside the trunk, and I used a small open end wrench to bend the rod slightly to get it to fit into the tabs. The final step is to position the left side of the rod so the torque will hold the lid open. I used a small open end wrench, placed it over the tip in the slot and rotated CW upward until straight part of the rod slid over the hook to hold it in place. This last step had me concerned that I could bend or break the rod, but I went slowly and carefully and was quite happy when it snapped into place and held the lid open.
Apr 16, 2012 | Chevrolet Malibu Cars & Trucks
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
How to OPen a UJDA 340 Cd Burner
near the right-side of the front, there is a button that SHOULD open the tray when pressed.
If that fails, there is a 'manual' release. Below and to the left of the button you should see a small hole. Un-do a paper-clip and insert the end into the hole. You will feel resistance and then it should 'release' the tray as when the Button is pressed.
This should only be don with desktops when the power is off as it will try to auto-close. The model you describe is typically for Laptops etc. and does not matter if power is on, but you should not attempt while the drive is being accessed, to avoid damage to the disk.
Jan 13, 2011 | Toshiba UJDA340 (P000345780) Burner
Quick Prep fell and popped into two pieces. I have the key match for the two haves but am unable to get the slots from the mixer end to slide into then male ends on the base end. Is there a way to...
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Make sure you line up the drive pieces and the logo goes on the side with the switch.Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
Nov 29, 2010 | Cuisinart CSB-33 Quick Prep Handheld...
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
How can i insert memory card into nokia 7100
Nokia 7100 Supernova is a low-to-mid-end phone in slider form factor work on Tri-band GSM network. It features TFT262k colors, FM radio, Bluetoothmag-glass_10x10.gif 2.0, USB 2.0, Opera Mini browser, Flash Lite 2.1.1, MicroSD card slot and 1.3 MP camera
yes, it has a micro SD card slot, u can see it ussually on d side of the phone it looks like a small thin square hole. then u can insert the SD card to the slot.
IF YOU THINK THIS ONE IS A HELP. VOTES ARE VERY MUCH APPRECIATED :))
Jul 26, 2009 | Nokia 7100 Supernova Cell Phone
Dvd wont eject
hi jodestar,
i am having the same problem with my player. how did you end up fixing yours?
Sep 23, 2007 | Philips DVDR3455H/37B
Cell Phones Logo
32 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
