Question about Janome Sewing Machines
Model 2139. how do I open body covers for maintenance?
  • Janome Master
  • 12,495 Answers
Consult your owner's manual. If you do not have one, here is where you can order one:
http://www.sewingpartsonline.com/instruction-manual-janome-2139n.aspx
Do not attempt to open your machine unless the manual instructs you to do so. Some newer computerized sewing machines require maintenance only in the bobbin area. Trying to open the cover in other areas could break it.
Posted on Jul 22, 2015
SOURCE: Download a Janome (Jem 639) sewing machine manual
Just today  i got out my little janome i bought years ago and it is this model.  There was no "manual" with the machine.  All that came with it is a large 20X14 two sided print out.  I can scan and send this to you with an email address.
Posted on Mar 02, 2009
  • 2386 Answers
SOURCE: sewing machine manual for janome harmony 2039
go to this site www.ifixmachines.com and you can buy your new manual
Posted on Sep 15, 2009
SOURCE: my janome sewing machine isn't locking the thread
If u r new to using sewing machines please take some ones help who knows using any machine. You obviously are not fixing correctly. It should click in right place and the machine shd be able pull the thread before u begin stitching.
Posted on Oct 17, 2009
  • 255 Answers
SOURCE: janomes sewing machine bobbin
Hi. Check to make sure the needle is in correctly. There is a flat side on the needle shank and that has to be facing a particular way. For most modern machines, the flat side of the needle faces to the rear, away from you, but it's always a good idea to check the manual to make sure on your machine. If the needle is bent, that can cause the same thing, but it's almost always that the needle is in wrong.
Happy Sewing!
Robbie
Posted on Apr 17, 2010
  • 1788 Answers
SOURCE: Is there somewhere I can order a replacement part
Try www.sewingpartsonline.com and put in Janome then your model number, they have all kinds of parts for sale. They may have your part or call Janome at 1-800-631-0183
Posted on Oct 04, 2010
Need bobbin case, shuttle race cover and shuttle body for a white sewing machine model 793... where can I find them?
Probably by finding a machine similar to yours and use its parts on your machine. Try auction sites like eBay...
Jan 23, 2017 | White Sewing Sewing Machines
How can I open/clean hook system?
Unable to assist without knowing the make & model. Consult the owner's manual. There should be instructions re how to remove the bobbin to access the hook area. Check the maintenance section.
Feb 16, 2016 | Sewing Machines
How to check fuse of janome 2139 sewing machine
Do you have a Manual?
If it is not in there, they intended it to be a Service item.
Mar 29, 2015 | Janome Sewing Machines
How to remove a sewing machine cover?
Most machines have some sort of clip or clamp near the bottom to release the cover, if it is the carrying case you're trying to remove. If you are trying to open the machine to see the motor and moving parts, many of them simply pop open at the side or top, or you may need to remove some screws. The model name would help.
Jul 18, 2014 | Bernina Sewing Machines
Nelco sewing machine 234F - stitch length knob wont turn
My Nelco Sierra 234F stitch length dial was stuck. Turns out it's pretty easy to repair if you are handy with tools.
Remove top of the machine. Remove set screw holding stitch length mechanism to body about half-way down inside. I loosened the screw and used a magnet to retrieve the screw and washer. Gently pull mechanism out the front, jiggle a bit to disengage rear cylinder from lever and pin inside body. When out remove two screws holding rear cylinder to mechanism and remove, note that the opening in the cylinder should be up when the dial is set to "button hole."
Remove the small snap ring holding the reverse button push rod and spring and pull it out. Remove snap ring holding outer cylinder onto inner cylinder...this probably requires a snap-ring removal tool.
Work the outer cylinder free from the inner cylinder by using lubricant (maybe let it sit over night), twisting with a wrench, whatever it takes. The problem is that the oil/grease between the two cylinders has dried out and become sticky.
Once the outer cylinder is off clean everything and verify the cylinders turn freely when assembled. Lightly file the cylinders smooth if you gouged them when taking them apart. Lubricate with oil or light grease, reassemble and reinstall the snap ring. Reinstall reverse button push rod, spring and small snap ring. Reinstall rear cylinder with the two screws, note orientation of opening in rear cylinder.
Installation is a bit tricky, you have to turn and wiggle the mechanism to get the pin on the lever to enter the side opening of the rear cylinder. Lifting the lever and pin mechanism from the top can help by moving the pin rearwards. It took me a few tries.
Once it's in orient the set screw hole in the outer cylinder under the set screw opening in the body and reinstall the set screw and washer (I used a magnet to lower the pair into the screw hole).
Reinstall cover and you are good to go. If you drop the set screw or washer remove the bottom and retrieve them, or fish them out with a magnet if you can see them.
Jun 01, 2012 | Sewing Machines
Janome sewing machine Harmony 2139 The bobbin thread is not connecting with the needle to make a stitch. We have put in a new needle. Using needle 4 tension
Take out the thread. Now cut the end of thread using a pair scissors. Now try that again. Once i had the same problem and later found out that the uneven end of the thread caused problem by refusig to move around freely hence preventing the stich formation
Dec 02, 2010 | Janome Sewing Machines
How do I open the machine to change the light bulb. model ls-1217
Hi
Do you have a manual?
You can download a free manual from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Click on the maintenance section of the manual. The first part of this section shows how to change the light bulb.
Hope this helps!
Nov 12, 2010 | Brother XL-3510 Mechanical Sewing Machine
How do I disessemble Singer 6038 sewing machine
There are hidden plastic snaps inside the seams of the front and back shells of this model. You will think you are breaking it if you try to pry them apart and you may. Wish there was a better way.
Feb 10, 2010 | Singer 6038 Mechanical Sewing Machine
How do I disassemble a Brother sewing machine? I have it almost open but one part, below where you wind the bobbin, will not come apart. Part of a screw that holds a piece in place fell out while trying...
Disassemble your home sewing machine for routine maintenance Many sewing machine repairs can be made at home, and most repairs can be completely avoided through routine sewing machine maintenance. This tutorial shows you how to carefully disassemble your machine to give it a round of maintenance. You will need a screwdriver - make sure not to lose any of the screws! How to Disassemble your home sewing machine for routine maintenance
Oct 11, 2017 | Brother Sewing Machines
Sewing Machines Logo
95 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
