Question about Garmin Edge 510 Cycling Computer Performance Bundle
The unit will not turn on, also the unit will not turn on when charging.
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Does the unit have to be turn on to charge the unit
The device does not need to be turned on to charge it, all you have to do is to connect the charger to it and it will indicate that it is charging with the power light coming on or something. So charging does not require you to turn on your unit, Also you can charge it while it is on. Either ways you can charge you unit, either on or off.
Hope this helps.
Dec 22, 2010 | GPS
Red light and beeping as if its not charged but green charge light turns on when i charge it. no sound from babys room
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Aug 03, 2010 | Graco Digital Deluxe Imonitor Baby Monitor
When I plug in the ac adaptor to charge unit,the instructions state the chg light will go off when charged. Is it possible that it is charged and the light stays on. I charged it (in the off position)...
The unit still,work?The battery when it low,the battery light turn yellow or red?Than when it fully charge it turn green?Just unplug the unit and use it dosen't matter,if the light don't turn off the light,that find.Or the battery is old and not taking full charged anymore that another resoan the charging light still on.
Jun 14, 2010 | Mintek MDP-1770 Portable DVD Player
My psp has not turn on, but it was charging the orange light was appearing, but when i turn it on the green light hasnt appearing
Please make sure that the unit is fully charged. I am charging my unit for 2 hours. Also, please try to turn it on while the power adapter is connected to the unit.
Aug 04, 2009 | Sony PlayStation Portable (PSP) Console
Charge light orang on for a second and turn off unit not charged.
This kind of problem is usually caused by either of this 3 things: Either the problem is the battery not being able to charge anymore(bettery would need to be replaced), or the charger does not give any charge to the batter(recommend try another charger), or last would be the console charger port( would need to replace console, or repair charger por,not recommended)
Mar 10, 2009 | Nintendo DS Console
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Garmin Street Pilot C330
Check the fuse at the tip of the power cord. Unscrew the round black plastic and this will release the fuse. Otherwise there could be a problem with the power cord. If the cord is defective, replace only a Garmin replacement.
Apr 06, 2008 | Garmin StreetPilot C330 GPS Receiver
okay people... this is a long one, but I just did it for two units that were having this problem and it worked both times.
The problem is the unit sat on the shelf and doesn't have enough power to operate its charging cycle.
Take an extension cord and plug in the outlet charger while you also plug it into your cigarette lighter... now attempt to charge it (you will hear the familiar alarm). Now, turn on the LED light... after a short time, turn off the light and the unit will begin to charge regularly. You can then use one of the chargers to finish the job.
By doing this you are providing plenty of power to the battery while the light drains it at a slower rate... kinda forcing the battery to condition/cycle; it's just allowing the battery to take the charge. Hope this helps.
Nov 25, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Psp battery won't charge
Its a problem with the unit's charging pins..you will have to get it replaced it shouldn't cost you more than 10$..
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Garmin Edge 510 Cycling Computer Performance Bundle Logo
511 people viewed this question
Top Garmin Cell Phones Experts
Computer Repairing
Computer Repairing
Andrew Taylor
Andrew Taylor
richie46
Are you a Garmin Cell Phone Expert? Answer questions, earn points and help others
