Question about Radio Shack Pro-97 Handheld Scanner
Pro 97 for the techies
I've owned my Pro 97 since 2006 and this problem has popped up a couple of times, but recently a lot. The keypad doesn't work. Not a lock-out, it won't work at all. Pulled the back, loosened the bulk, to the pad, cleaned and reassembled, still not working properly. Any ideas?
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Apr 26, 2012 | Cars & Trucks
My son's KTM 50 senior pro doesn't start. has petrol vapour coming out of the pipe.
The engine is running too rich. The carburator needs tuning to get the fuel mixture correct or the choke may be stuck in a partially closed position.
Feb 11, 2012 | 2006 KTM 50 Senior Adventurer
Hi. I've recently acquired a Lenovo Thinkpad X41 tablet PC (1866-CRG version) but unable to work out how to turn on the wifi - there doesn't seem to be a function-key or switch assigned for that...
I had the same issue when i first got my used x41, i downloaded Intel Pro/Wireless 2915ABG Network connection driver onto external drive then installed onto cdrive. Im no pro so hope it helps..
Sep 12, 2011 | IBM ThinkPad X41 Tablet PC
The toaster won't stay down, it keeps popping up. I've tried to adjust the level of toasting but that doesn't help. What can I do to fix it so the toaster will stay down??
Hello, rex
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 02, 2011 | Back to Basics TEM-500 Egg & Muffin...
Shark steam pocket mop little or no steam.
aHi,
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
a
Jun 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Scanner works but keypad will not
The keypad may be locked. Lock and Unlock procedure is below:
To turn off the Keylock, press FUNC then keylock.gif. The scanner beeps 3 times and Key unlocked appears.
To turn on the Keylock, press FUNC then keylock.gif. Key locked appears for about 1 second. Key locked appears when you press any key.
Here's a link to your scanner manual:
http://marksscanners.com/97/97.shtml
Oct 08, 2009 | Radio Shack Pro-97 Handheld Scanner
2000 BMW 528i eml light on
coils, air mass sensor, O2 sensors---pre and post cat. Vanos timing. Look at all the things that can go wrong.
lots of money...only bmw knows how to effectively work on it.
HOnda, toyota isuzu, kia. easy to work on.
Aug 14, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
Keypad not working
i have a lf cookie kp 500 and it is all touch screen and none of the keys work i can receive calls but cannot make calls or use any of the features
Oct 13, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Pro-97 20-527 scanner
You can download the manual from the link below: http://support.radioshack.com/manuals/ome20-527.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
179 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
