Question about Makita Angle Grinder 4.5" 9524NBX
How to inspection power tools ? - Makita Angle Grinder 4.5" 9524NBX
I have makita power tools do they charge for just checking the tools?
Yes they will everyone would charge for inspections unless it was part of an service contract then they may suggest parts may fail soon to get some cash out of it
Aug 07, 2017 | Makita Drills
I have a 2006 Chevy uplander, 3.5l, and when I turn the key to on position only the check engine symbol light's up on the instrument cluster and when turning key to cranking position nothing happens.
This is what would be done at the dealer or any good repair shop !
Perform the following preliminary inspections:
Ensure that the battery is fully charged. Refer to Battery Inspection/Test .
Ensure that the battery cables are clean and tight.
Inspect for any open fuses.
Refer to Power Distribution Schematics and Electrical Center Identification Views .
Inspect the easily accessible systems or the visible system components for obvious damage or conditions that could cause the symptom.
Ensure that the grounds are clean, tight, and in the correct location.
Refer to Ground Distribution Schematics and Power and Grounding Component Views .
Inspect for aftermarket devices that could affect the operation of the system. Refer to Checking Aftermarket Accessories .
Search for applicable service bulletins.
Did you find and correct the condition?
System OK
Go to Step 2
Install a scan tool.
Does the scan tool power up?
Go to Step 3
Go to Scan Tool Does Not Power Up
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to establish communication with all of the control modules on the vehicle. Refer to Scan Tool Does Not Communicate with Class 2 Device for the modules you should expect to observe.
Does the scan tool communicate with all of the expected vehicle control modules
Important:
To ensure that retained accessory power (RAP) mode is inactive, if equipped, open the drivers door during the following step.
The engine may start during the following step. Turn OFF the engine as soon as you have observed the crank power mode.
  1. Access the Power Mode parameter on the scan tool.
  2. Rotate the ignition switch, operate the ignition mode switch, through all positions while observing the Power Mode parameter. Refer to Body Control System Description and Operation for a list of the power mode states that correspond with each switch position.
Does the Power Mode parameter reading on the scan tool match the ignition switch position for all switch positions?
Go to Step 5
Go to Power Mode Mismatch
5
Attempt to start the engine.
Does the engine crank?
Go to Step 6
Go to Symptoms - Engine Electrical
Turn the ignition to the START position.
Go to Testing for Intermittent Conditions and Poor Connections
Go to Step 3
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Verify that the transmission is in Park or Neutral.
  4. With a scan tool, observe the IMS parameter in the powertrain control module (PCM)/engine control module (ECM) data list.
Does the scan tool display Park or Neutral?
Go to Step 4
Go to Range Selector Displays Incorrect Range
  2. With a scan tool, observe the Starter Relay Command parameter in the PCM/ECM data list.
  3. Turn the ignition to the START position.
Does the scan tool display Yes?
Go to Step 6
Go to Step 5
With all the modules on your vehicle you really need to start with a professional grade scan tool to see if all are communicating .
Aug 17, 2015 | Cars & Trucks
03 trailblazer is hard to start I have to turn the key 15-20 times before it starts. I put in new fuel pump, filter, relays good starter good just hard to start any suggestions on how to fix this issue. ...
You can check the fuel pressure regulator ,
  1. Inspect for a fuel leak from the fuel pressure regulator vacuum port.
Is the fuel pressure regulator leaking fuel ?
This next test needs a scan tool with data reading capability's ,not a code reader ! Are you familiar with OBD 2 ? All the sensors , coolant , O2S , TPS , MAF , Intake air temp. etc. Sensor/System
Monitor the engine coolant temperature (ECT) sensor with the scan tool. Compare the engine coolant temperature with the ambient air temperature on a cold engine. If the coolant temperature reading is more than 5 degrees more or less than the ambient air temperature on a cold engine, check for high resistance in the coolant sensor circuit.
Inspect the PCM grounds for being clean, tight, and in their proper location. Refer to Power and Grounding Component Views in Wiring Systems.
Inspect vacuum hoses for splits, kinks, and proper connections, as shown on Vehicle Emission Control Information label. Inspect thoroughly for any type of leak or restriction.
Inspect the air intake ducts for being collapsed, damaged areas, looseness, improper installation, or leaking, especially between the mass air flow (MAF) sensor and the throttle body.
Inspect for air leaks at throttle body mounting area, mass air flow (MAF) sensor and intake manifold sealing surfaces.
Inspect the wiring harness for poor connections, pinches, cuts, or other damage.
Inspect for loose, damaged, or missing sensors and/or components.
Really need to check sensor PID'S with a scan tool, An maybe a scope too ! PID'S are parameter identification . All the sensors operate within a set voltage parameter , like the coolant temp. sensor an if it's off it can affect fuel delivery !
This
Mar 15, 2015 | 2003 Chevrolet TrailBlazer
Why scan tool doesn,t connect to truck.
ecm has been replaced????? was it programmed ?
Sep 27, 2017 | 2003 Chevrolet Avalanche
Bissell 1623 sprayed used water from tool
Hi Beverley, you may want to have your machine inspected by a Qualified Technician at one of our Authorized Service Centers.
Here's a quick link to locating an Authorized Service Center in your area. http://www.bissell.com/service-centers/?cid=ccsocial
Jan 26, 2013 | Bissell 1623 Steam Cleaner
98 corvette what is the proper procedure to bleeding the brakes
  1. Raise the vehicle on a suitable support.
  2. Remove all four tire and wheel assemblies.
  3. Inspect the brake system for leaks and visual damage.
  4. Inspect the battery state of charge.
  5. Install a scan tool.
  6. Turn ON the ignition, with the engine OFF. With the scan tool, establish communications with the electronic brake control module (EBCM). Select Special Functions. Select Automated Bleed from the Special Functions menu.
  7. Bleed the base brake system. Follow the scan tool directions until the desired brake pedal height is achieved.
  8. If the bleed procedure is aborted, a malfunction exists. Perform the following steps before resuming the bleed procedure:
    1. If a DTC is detected, check for the cause and repair as necessary.
    2. If the brake pedal feels spongy, perform the conventional brake bleed procedure again.
  9. When the desired pedal height is achieved, press the brake pedal in order to inspect for firmness. Remove the scan tool.
  10. Install the tire and wheel assemblies. Inspect the brake fluid level.
  11. Road test the vehicle while inspecting that the pedal remains high and firm.
  7. With the scan tool, establish communications with the electronic brake control module (EBCM). Select Special Functions. Select Automated Bleed from the Special Functions menu.
  8. Bleed the base brake system.
  9. Follow the scan tool directions until the desired brake pedal height is achieved.
Jan 03, 2011 | 1998 Chevrolet Corvette
I went to get my 2002 Mitsubishi Montero Sport inspected and they said the computer would not communicate with the inspection computer. Any ideas as to why that would happen?
Did their computer power up? sometimes their computer gets power from your truck and if the fuse is blown, it wont power up (you would think they could figure that out??) Make sure fuse #5 is good. I would have them try another scan tool.
Nov 23, 2010 | Mitsubishi Montero Sport Cars & Trucks
I went to have my 88 towncar inspected and the guy said i need a power steering belt, the power steering pump&box leak and the pitman arm is loose. what kind of tools am i going to need to do this...
NO. Take it to a shop. You cant afford a mistake in your steering system.
By taking it to another shop, dont go back to the inspection station for the work, you will get an independent review of the problem and possibly a smaller repair bill. Seldom does a pump and steering box go out at the same time. I bet you just need a pump or steering box and it sprayed oil all over the place. A pitman arm can be a bear to replace without the proper tools . Have a shop fix it so you will have peace of mind.
Apr 09, 2010 | 1988 Lincoln Town Car
Disposal will not turn on, when you switch on it makes a dull sound as if it is jammed
Inspect the interior of the grinder chamber (power off) for things like dinner wear, bones, or similar objects. Check the motor bottom for a tool recess that accepts a hex (or other bit) key to turn the motor in the either direction. Try the tool back and forth until it is free to turn. Then inspect the grinder chamber again and fish out whatever was jamming it. Hope this helps!
Mar 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Makita Angle Grinder 4.5" 9524NBX Logo
320 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
