Question about Audiovox Televison & Video
Is there a way to open the setting menu with out a remote for a audiovox ADV300 dvd player.its stuck on pan scan.
SOURCE: Aspire Digital AD-N820B DVD-R stuck in Progressive Scan ( PSCAN )
I just had the same problem with the same model but I was able to figure it out after a while.
From the remote control:
SETUP
Scroll left or right to the PREFERNCES menu.
Scroll down to the bottom until DEFAULT is highlighted.
HIt the PLAY button in the remote while RESTORE or RESET is highlighted.
The DVD player was reset back to factory settings within 10 seconds.
Posted on Jan 01, 2008
SOURCE: Magnavox MDV560VR DVD Player Stuck in Progressive Scan
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Posted on Apr 04, 2008
SOURCE: two dvd's stuck in player
you cant get the system to open until repairing it but to get ur cds open ur system and take apart the place where the disc sets to start playing the movie
Posted on Jul 31, 2008
  • 4 Answers
SOURCE: need to reset my dvd player
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Posted on Mar 12, 2009
SOURCE: Magnavox DVD/VCR player stuck in progressive scan mode
Try holding down on your dvd stop button. Hold for several seconds. This may work. Good Luck.
Posted on Nov 17, 2009
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Screen wont light
Are you still under warranty with this product? Have you tried to reset the DVD Player to the factory settings. You can do this by opening up the menu and on the main page highlight preferences and press enter.Now go to the default setting and highlight it and press enter. This will reset the DVD player to the original settings.If this doe not solve your problem you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them the problems you are having. They will be able to tell you how to get the unit serviced. I hope this information helps you with your problem.
Mar 24, 2009 | Audiovox D1210 Portable DVD Player with...
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Audiovox portable dvd PVS6360 unlock codes
Audiovox code hack for DVD players
1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
Dec 13, 2008 | Audiovox D1210 Portable DVD Player with...
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Jensen VM 9512 DVD Player
goto the set up menu, tap the language tab, ON THE REMOTE push "stop, stop, 5,4,3,2,1" and the secret menu will pop up
Mar 19, 2008 | Audiovox VM9512 Car DVD Player
Two dvd's stuck in player
Dec 21, 2007 | RCA DRC8300N DVD Recorder/VCR
SETUP
Oct 11, 2007 | Aspire Digital AD-900 DVD Player
Televison & Video Logo
43 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
