Question about Zanussi Dishwashers
The door latch on my zanussi built in dishwasher is stuck open so door won't lock when closed. Any ideas? Thanks in advanced.
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Posted on Dec 28, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
jonniewalker
  • 1031 Answers
SOURCE: Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Posted on Sep 20, 2008
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
Oct 08, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Rinse cycle continues after the door is open
There is a door interlock within the door assembly. I believe it's mechanically stuck rather than needing replacing.
Turn off & unplug. You should be able to get to the internals of the door via screws around the edge. The interlock will be very close to the handle catch. Check operation by inserting a dummy catch to lock onto it.
If it is stuck solid - order a replacement.
Aug 04, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Soap door latch won't latch close
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Creda plan Integrated Dishwasher fault
door latch is in wrong position, split the door so you can see whats what and change the position of the switch
May 16, 2007 | Creda 24 in. DWI34 Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
