Question about Honda Garden
Hru19r honda mower was running fine and then just stopped and won't start. Drained fuel from carby as well,checked spark all good any ideas?
    Master:
  • 969 Answers
Flush gas tank, add fresh gas with Stabil. Use clean air cleaner. Remove clean/replace plug. Take bread wrapper, clean plastic off 2 inches, use to clean port from bottom of carb up thru carb after removing float and needle valve. Reassemble.
Posted on Jul 04, 2015
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
#1 Taper
  • 1041 Answers
SOURCE: brand new honda lawnmower starts and runs fine then backfires
There should be 1 or 2 screws on the carb. You will probably have to remove the air breather to get to the screw(s). I've been seeing a lot of these types of questions, new equipment not running properly. Factory settings were not set properly.
When you find the screw(s), screw in a clockwise direction until it stops; DON'T SCREW DOWN TIGHT, JUST UNTIL IT STOPS. Then unscrew counter clockwise 1 1/4 turns. Try starting.
Continue this process, 1/4 turn at a time up to 2 1/2 full turns. If you forget where you are at on the turning process, start over by screwing back down. Then pick up process where you left off.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
  • 10865 Answers
SOURCE: Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Posted on Sep 14, 2009
Why does my briggs and straten model 313-707 hard start then dies after a few seconds when it is running it acts like it's starving for fuel replaced fuel filter fuel cap and cleaned carb
Try replacing the plug.could also be a spark problem from the coil .you can purchase a spark tester which you can fit between the plug and lead .pull start mower and watch if spark is good.if ok then get a can of carby clean start mower and spray carby clean spareingly while running and if it keeps going the fuel is the problem
Aug 14, 2014 | Garden
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Honda HRR Mower
remove the carby are clean the corrosion from the main jet and needle seat hole
check for fuel flow through the metal tap as they corrode internally blocking fuel
Sep 17, 2017 | Garden
John Deere riding mower Model 115 won't start
fuel related if it starts and runs with a squirt
take fuel tank off and clean it out
have to re check the carby
float , needle or float level clogged jet in carby
Apr 28, 2017 | Garden
Bike has a spark and cleaned out carb will not start, put fuel in plughole would not fire, it just stopped when going on road, charged battery, so it turns over well, checked valve in petrol tank vaccum...
if you have good blue spark and it fires when fuel is added externally , then the problem is fuel flow through the carby
have the carby professionally overhauled or get a new carby
make sure that the gasket to the manifold / head is in good condition
May 06, 2017 | Honda Runner Pure Jet Motorcycles
I have a Baldor 6000W generator with a gx340 11hp engine. I have drained the tank and carb and put new gas and sea foam in it. Also I have replaced the spark plug and fuel filter. The engine will...
It sounds like the engine is not getting enough fuel for it to run. First check that you have the fuel tap in the on position. If the fuel tap is on then the carby might be blocked or the needle & seat are not working properly. Turn the fuel tap off. Then take the fuel bowl off. You will then see a plastic float,turn fuel tap on. Fuel then should be flowing from carby. Push the float up and this should stop the fuel from running. Do this a couple of times to ensure that it is working correctly. If all is good after that then turn fuel tap off. Put fuel bowl back on, turn fuel tap on and test. If no luck, turn fuel tap off. Then you will need to take the carby off the motor and clean it using carby cleaner. Be sure to spray cleaner in all holes of carby and blow out carefully with air compressor. Put carby back onto motor and turn fuel tap on and test.
Jan 06, 2011 | Honda 8 HP Engine
Brand new Pope Spitfire 40 lawnmower won't start
Caren,
Drain the fuel completely if it is older than 1 week. Make sure you undo the bolt at the bottom of the fuel bowl to ensure all old fuel is drained. Refill with fresh fuel (premium unleaded) and try again. If it still does not work then remove the spark plug and rest it on the metal of the mower while still attached to the silicone ignition wire. Have someone hold the cut out bar to the handle (as you normally would to run the motor) and pull the cord. You should see sparks being emitted from the spark plug. (Make sure there is no fuel nearby) If you cannot see any sparks then replace the spark plug with a new one and repeat this process. If you still cannot see any sparks being emitted after attatching the new plug to the silicone wire, resting it on the metal of the mower, and pulling the cord to start it as you normally would, the mower will need to have the resistor and capacitor checked by a professional repairer as no spark is being generated.
Good luck.
Allan
Jun 06, 2009 | Garden
Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Garden Logo
102 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
