Question about Toshiba Computers & Internet
My toshiba satellite m65 s9092 wont boot up - Toshiba Computers & Internet
    Top Expert:
  • Toshiba Master
  • 5,030 Answers
Have you tryed starting up in safe mode.
if you can you can try and sort the problem out from there.
Posted on Apr 01, 2015
geminii_lady
  • 87 Answers
SOURCE: Toshiba screen goes blank when it is opened too far
Sounds like a problem with the ribbon for the screen being either having a loose connection or getting nipped. Pretty common on laptops because the ribbon runs along by the hinges on the base and then up to the screen.
Hopefully you will be able to access the ribbon on your model by removing the plastic bezel which lies just above the keyboard. The ribbons I have seen are about 1/2 inch wide and as I said connect on the base and the screen. The connection just pushes in. If its loose at the connection on the base then obviously push the connection fully home. If it's getting nipped then reseat it so that it does not get caught. ***NOTE*** a problem could arise if the ribbon has actually been damaged from being nipped - opening the laptop could cause it more damage and then you could lose the screen until you replace with a new ribbon. These can normally be purchased on places like Ebay and don't cost an arm and a leg.
If this helps, I'd appreciate feedback so other people can use this as a solution. Thanks
Posted on Nov 22, 2008
  • 144 Answers
SOURCE: can't remember bois password
You could try flashing the bios, but your wiggle room is limited. You may or may not see effects on the password. I would try the default 0000, or 00000. If that fails, i would look into flashing. It is hard, and risky, but it may be your only way out. Unfortunatly i would be liable if i told you how, so i would look up a blog about it.
Sorry i couldn't help
Posted on Jun 25, 2009
  • 61 Answers
SOURCE: How do I replace the keyboard for my satellite m65
try this
http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M65/take_apart_laptop_1.htm
go to step 7
Posted on Sep 16, 2009
SOURCE: toshiba m65-s9092 satellite laptop locked with bios password
Remove the battery, and the memory cover (1 screw), and the memory module(s). Under the bottom memory module, there is a white sticker (the bigger sticker)... remove that, and there is a small copper lead labeled J2 that looks like two E's mated with each other, you need to short the E's to each other for about 30 seconds with something metal. Put at least one memory module back in, and the battery, and try booting. If it still has a password, try again for a little longer, or press a little harder with the metal object to ensure you are making a connection.
Posted on Oct 07, 2009
adracamas
  • 344 Answers
SOURCE: where can i get the
Hi there... go to this site here... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download and click in your info... adracamas_3.png
Like so. Click ( GO ). There you are.
Posted on Mar 24, 2011
Hi, i have an Toshiba Satellite M65-S9092 with XP installed. everything still stock inside but operating system, had vista when we got it. this laptop shuts down at random times... no booting down, just...
I realise that you have checked the fans for operation, but they could still have a build up of dust which stops them from cooling efficiently, the main fan blows air through a heatsink and you can often get quite a build up between the fan and the heatsink. If this is not the case, or clearing it doesn't work, check your event viewer for any recurring errors, instant shutdown could be faulty ram, faulty hard drive or the heat problem.
I hope this helps
May 05, 2011 | Toshiba Satellite M65-S9092 Notebook
Can't remember bois password
Jun 25, 2009 | Toshiba Satellite A135-S2276 Notebook
Will not turn on, no lights at all
Try to remove the battery, and plug it into the wall. If it then boots, your battery has failed. This happens frequently. If it still wont boot you will need to take to someone to see if the board has died or other issues. Hope this helps
Nov 30, 2008 | Toshiba Satellite M65-S9063 PC Notebook
Nov 22, 2008 | Toshiba Satellite M65-S9092 Notebook
Toshiba m65-9092 locks up
I guess the fix on this one depends on your knowledge of taking apart computers. The problem sounds like there is something loose (either not plugged in all the way, or loose wire). The other option is a crack in a circuit board. If you feel that you know that you have enough computer hardware knowlege to have a look inside, I would check out this site. I use it frequently.
On this page are 2 tutorials about your model that will help you take it apart.
If you don't feel up to it, take it to a repair shop. Hope this helps. If you have any other questions, post another comment.
Nov 14, 2008 | Toshiba Satellite M65-S9092 Notebook
Toshiba m65-s9092 satellite laptop locked with bios password
Nov 07, 2008 | Computers & Internet
Cannot open laptop LG LS70 to fix the power input connector
you will need to open the upper part of your laptop starting by detaching horizontal panel at the top of your keyboard and removing your keyboard. there should be screws that you should open.
Nov 03, 2008 | Toshiba Satellite M65-S9092 Notebook
Motherboard
Try dismantling your laptop and one by one remove the module components like the Wifi card, Lan modem module (if possible) and try booting it up again and see if this problem will be solved.
What did you do prior to experiencing this particular problem?
Apr 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
