Question about Kipor Electrical Supplies
What is code 502 in my kipor electric generator and how can i fix it?
CarlGehrke
  • 169 Answers
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
adnanbhatti
  • 1188 Answers
SOURCE: Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Posted on Aug 20, 2009
  • 905 Answers
SOURCE: I have a kipor ig6000 generator.When i connect my
Your generator is running a bit too fast, and the frequency is greater than 60Hz. Most generators are setup for 62-63Hz no load. You can adjust this at the governor for the engine.
Another possibility is that the alternator is providing electric with a large amount of harmonic distortion, which some appliances don't tolerate well (dirty power). Try adding a noise filter between the generator and espresso maker and see if that helps. The espresso maker may also expect to be grounded, which the generator is not able to provide (unless you are driving a ground rod). The noise filter may also require a ground as well.
Posted on Jan 04, 2010
  • 342 Answers
SOURCE: Iam looking to download a manual for a Kipor KDE
looks very similar to the kde 6700 ta
Posted on Apr 04, 2010
  • 6468 Answers
SOURCE: kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
Posted on Sep 08, 2012
My kipor generator runs but produces no power. What is likely to be the problem
Is there any circuit breakers or main cut off switch in the off position? If so start the generator and turn on all circuit breakers or cut off switches.
Jan 28, 2018 | Kipor Electrical Supplies
My kipor KGE 6000 Ti generator overload light is on, and there is no current output.
Read the instruction manual. If you are certain you did everything right and the generator does not behave as intended then return it to the supplier as faulty.
Jan 27, 2018 | Kipor Electrical Supplies
I have a Kipor IS6000 generator that drains fuel from the plastic tube on the back side of the carborator when the generator is running. What can be the cause?
check for a small fracture on the tubing caused from age and flexing from vibration. It is usually right where the tubing comes off the carburetor.
Oct 22, 2017 | Kipor Electrical Supplies
Kipor generator shut off after start with over load light.
Check your load and reduce if is more than the generator can handle.
Mar 13, 2017 | Kipor Electrical Supplies
My kipor 7000 diesel generator is burning avr. Replaced avr don't last beyond few days. Can someone tell me cause
You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
Jan 11, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Kipor generator starts ok but will not provide electricity to apppliances
Sep 05, 2012 | Kipor RV Generator Sinemaster IG3000
Electrical Supplies Logo
Top Kipor Electrical Supplies Experts
Vernon Taylor
jhnolson
mark52001p
Level 1 Expert
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
