I bought this machine from a deceased estate, not very old. the problem is that the clothes have streaks of lint/dirt on them, even on the deep rinse cycle
  • Washing Mach... Master
  • 5,323 Answers
You obviously have a build up of fabric softener and or detergent soap in the soap and sofetner dispensers and their tubing. Need to be cleaned perhaps running couple loads of vinager and water
Posted on Apr 20, 2015
  • 1294 Answers
SOURCE: Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Posted on Apr 14, 2007
SOURCE: Candy GO 146 Washing Machine
Buy Gorenje.
Posted on Oct 04, 2008
  • 6 Answers
SOURCE: Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 08, 2009
shinn8
  • 85 Answers
SOURCE: washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
Posted on May 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Soap streaks on dark clothes what do i do?
reduce the amount of detergent being used as more is not better
use a liquid instead of powder
make for longer rinse cycle
use a softener to help remove detergent in the rinse.
reduce the amount of clothes being washed at each time.
Apr 08, 2015 | Washing Machines
White streaks on dark clothes
The white streaks are of soap build up on your machine tub. You can get ried of that by putting cascade dish washing soap in your washing machine and run full cylece , with out clothes.
Apr 13, 2013 | LG WT4801CW 3.7 cu. ft. top load washer
There are streaks (lint?) left on clothes after
It is not on the machine, it is on the detergent that you are using and the amount of water for per grams of detergent, maybe you are putting to much detergent, try to lessen the detergent and more water instead.
Nov 06, 2009 | Kenmore Washing Machines
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
Jun 18, 2009 | AEG Lavamat 88840 Front Load Washer
Feb 20, 2009 | Kenmore Elite 21086
The lint is not being washed from machine. All dark clothing has lint residue. How can I rectify this problem please? Currently my husband using damp cloth has to wipe over black clothing extensively prior...
the self cleaning lint filter seems to be clogged. before you replace it try this cheap/ easy remedy.
  • run a load with no clothes on high water level, hot water and a gallon or two of bleach.
  •  no soap.
  • do an extra rinse after to make sure you rinse all the bleach away before putting more clothes in.
the lint filter may be defective since it has always had this problem, but its worth a try.
Jul 01, 2008 | Maytag Washing Machines
Oki C5800 prints magenta streaks
Streaks can be caused by a number of things
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Apr 28, 2008 | Office Equipment & Supplies
Wet clothes, water in soap dispenser
Next check your drain, where the hose goes in behind, snake this out. And dont shove the hose in too deep, into the standpipe that is.
If this helps, rate me please.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
