How to change your grade - Computers & Internet
    New Friend:
    Problem Solver:
  • 11 Answers
SIR, IF I MAY, THERE ARE BUT TWO POSSIBILITIES, 1) STUDY HARDER 2) CHEAT OFF SOMEONE SMARTER
Posted on Mar 29, 2015
Is it ok to put shell oil 15w40 in a rave 4 toyota
1st find out what Toyota specs are , but in general , no , do not use any grade oil other the specified .
Mixng the oil grades id just wrng and will destroy your $5.000 engine over a few dollar saving...
DO NOT CHANGE THE GRADE OF OIL , USE ONLY THE RECOMENDED GRADE... THE BRAND : CASTROL GTX ONLY
most other oils are recycled garbage...
Dec 16, 2017 | Toyota Cars & Trucks
What grade engine oil is recommended for my 2c diesel engine?
depending on the ambient temperature of where you are that would be a good viscosity for low temperatures. When it gets hot in the area then change up to a 30w-50 viscosity. Make sure that you are using diesel grade oil as there are more additives in it than what is in petrol engine oil
Dec 31, 2014 | Cars & Trucks
How do I change the timing so I can use different grade of gas and not get the knocking?
NOT SURE WHY SOMEONE TOLD YOU THIS? BUT YOU HAVE A RANGE FOR YOUR TIMING HAVE TO CHECK SPECS BUT THAT HAS NOTHING TO DO WITH GASOLINE GRADE YOUR HEARING KNOCKING YOUR VALVES COULD BE GETTING SMUDGED AND GUNKED UP I RECOMMEND CHANGING OIL RUNNING A BOTTLE OF LUCAS OIL STABILIZER WITH OIL REPLACES ONE QUART ALSO LUCAS FUEL INJECTOR CLEANER 3OZ TO EVERY TEN GALLONS OF GAS YOU CAN DO THIS WITH 87 GRADE KEEP TIRES INFLATED PROPERLY FRONT END ALIGNMENT PROPER OIL THESE ARE ALL FUEL SAVING TECHNIQUES THAT WORK!
May 09, 2012 | 2000 Dodge Durango
What grade of oil doe a 2007 Suzuki Reno take. 5 30 or 10 30
Suzuki recommends 10w30 grade oil and it will need about 2.4 quarts of oil without a filter change and 2.6 with a filter change.
Dec 19, 2010 | 2007 Suzuki Reno Hatchback
How often do you change the motor oil? The motor oil filter? The automatic transmission oil and filter? What type of motor oil should be used?
Oil change recommended is every 3,000miles / 5000km for local short running around. If you clock up the miles quickly then extend the oil changes to 6,000miles /10,000km
Oil filter is every second oil change.
Use reputable multi grade oil 15W/40 or similar, Do not use standard SAE 30 single grade oil. You do not need to use synthetic / semi-synthetic oils either.
Oct 20, 2010 | 2002 Nissan Maxima
Oil type for 2006 dodge grand caravan
New cars and truck manufactures recomend differend types of grades of oil when the engine is new. What they don't tell you when the engine receives 30,000 miles on it the grade of oil can be changed for better lubrication. Use 10w30 for normal use upon changing oil.
Jul 05, 2010 | 2006 Dodge Grand Caravan
Oil capacity & recommended grade for 2004 yamaha xvs1100 v star classic
hi buddy the oil reccomended/grade 5w-40 i recomend using silkolene pro 4 plus 5w-40 AND ADD 3.6LITRES WITH OIL FILTER CHANGED OR 3.1LITRES WITH STANDARD CHANGE
Oct 02, 2009 | 2004 Yamaha V Star Classic
Oil change how much to refill, with filter change
starting from low grade to high grade depends 18.00up to 60 + $$
Sep 24, 2009 | 1996 Lexus GS 300
My wife accidently deleted the overall grade column on her Easy Grade Pro (version 3.6). How do we restore this coulmn. Right now the overall grade does not show up on the score chart screen. We have...
try left clicking on the bar where it says __ out of ___ students. you should be able to add a new column. then left clicking on that column you can change it to overall grade in the main grade menu option.
Sep 20, 2009 | Orbis Software Easy Grade Pro (EGPSING-W)...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
