Question about Garden
Mech choice line trimmer wont start cleaned spark plug it put but just doesnt have a bit of bite to start
  • 211 Answers
SOURCE: Ryobi 780 Trimmer No Spark - won't start
Hi
Check the spark at the plug,compression and carburation.Clean the air and the fuel filters.Check the muffler.
best regards savumihai71
Posted on Feb 12, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: Home lite String Trimmer Won't Start
be sure your kill switch is set to run positon and the wires from it arent grounding theirself out . Make sure your spark plug is
grnded to metal when you check for spark.(ground to head away from the spark plug hole
You may have a bad ignition module if you still have no spark or the flywheel keyway has sheared for some reason throwing it out of timing.(removal of flywheel is required to see if the keyways are aligned flywheel and crankshaft)
If your flywheel seems tight then you may be ok
not a high failure rate but it has happened.Gap your plug at .030 then.025 see if that makes a difference? keep going to a smaller gap to show you may have a weak module not able to jump a wider gap.
just a couple things to check hope this helps maybe
Posted on Jun 01, 2009
  • 115 Answers
SOURCE: Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Posted on Jul 06, 2009
  • 203 Answers
SOURCE: No Spark - Husqvarna 125R Trimmer
Check the wire that goes to the "OFF" button. See if it is by chance loose or cracked allowing a short. Beyond that, it would probably be the coil, but I would lean towards some type of a short, especially if you know the plug is OK.
Posted on Jan 10, 2010
Echo trimmer wont start, i replaced fuel line and filter, spark plug still wont start
Krissie, there should be two fuel lines. also take the spark plug out and pull the cord a few times to blow out any gas or whatever out of the cylinder. then put the plug in the spark plug boot and pull it a few times holding the plug head next to the engine block to see if it has any spark. if it don't probably the coil or switch is bad, if it has spark put the plug back in and give the opening of the carburetor a squirt of carburetor cleaner and try to start it. it should start then. if it does and dies the carburetor needs to be cleaned or rebuilt.
Dec 03, 2016 | Echo Garden
My curved shaft gas trimmer by troy bilt tb22 ec wont start
General rule: You need 3 things for an engine to start, fuel, air and spark. Do this test first (fuel)and this will eliminate the need to test for spark or air. Remove the spark plug, spray carburetor spray in the plug hole, a good 3 squirts, don't be afraid it won't hurt a thing. Put back in the plug and try and start the unit. Now if the unit starts to run for 3 to 5 seconds, you have a fuel problem for sure.
Your next step will be to clean the carburetor .. and that is a whole other lesson... BUT, simply go on you tube, type in how to clean a 2 cycle carburetor, you will have a ton of choices. Go with the one that has the most views for aure. Good luck! !
Sep 24, 2015 | Troy Garden
Wont start put new fuel in don't know if there was fuel in it before
usually they need carb cleaning but one thing i did in past when i got frustrated was remove the spark plug, drop a little gas (few drops), put back in and lol it has no choice but to start.
Mar 06, 2015 | Garden
Just brought new mech choice 25cc petrol line trimmer put petrol with oilmix in ,follwed instructions cant get it to start why,did we miss something out in getting it to start
How did you mix the fuel? Best to make it up in a jerry can. Mix the fuel and oil in the can. It may well be flooded. Try starting with ignition on, choke open and full throttle, might take up to ten pulls.
Sep 26, 2013 | Craftsman 25cc Gas Line Trimmer
Husqvarna 223l trimmer
put a meter to the spark plug wire and see if it fires. Make sure all lines are clean.
Jul 23, 2012 | Husqvarna 28cc Gas Line Trimmer
I have a weed eater trimmer that wont start. ben sitting for a couple years and i replaced the fuel lines andcleaned the carb. still nothing, what do i do?
Try cleaning the spark plug, make sure it sparks. Put some fresh gasoline in the tank, check start stop switch.
A easy way to check whether the problem is related to carb or not is:
remove the spark plug put some fresh gasoline in the cylinder, put the spark plug back
pull the starter a few times if it starts for a few seconds it means is related to carb.
Be carefully when handling gasoline.
Aug 05, 2011 | Troy Bilt Tb70ss Gas Trimmer
My petrol weedeater/trimmer wont start
a few easy steps does it spark if not change the plug
if it doesnt spark now it could be a split in the HT lead so change that
Make sure u have clean petrol/oil mix
If still no luck check the on/off switch for rust or water
if damaged clean
Jul 28, 2010 | Ryobi Three Trimmer Combo
Right fuel mix spark but wont start..priming bulb stays down-doesnt pop up. trimmer wont start.clean air filter too.
Your carburetor is plugged. What's happening, is the carb can't get fuel via the normal means, so it's trying to draw it through the primer system instead. This will require disassembly, likely a new diaphragm, and cleaning.
Feb 18, 2010 | Craftsman 25cc Gas Line Trimmer
New fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Jul 11, 2009 | Craftsman 25cc Gas Line Trimmer
Troy-Built TB70SS, 1 year old, will not start even after carb cleaning
check to see that the kill button is not stuck in the contacting position, and if it is, try to get it unstuck. WD40 should help. if it's not, then disconnect the kill wires. now try starting it. if it still doesnt start, then the spark generator is bad. if this is the case, you'll need a new trimmer, or have a small engine mechanic replace the generator. i think its called the coil, not sure at the moment it's 4:00 am for me. anyways, whichever is cheaper is best choice.
Jun 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
