Question about John Deere Garden
John Deere x300 series 2009 model I unhooked the kill wire and it started. But now my mower/pto will not engage is there a way to bypass the sensor?
  • Kprime
    Kprime Mar 29, 2015
    good morning, too sleeply last night. So, I assume this means with the kill wire off the engine runs, but if you put the kill wire back on it does not run?
    Sergeant:
  • John Deere Expert
  • 187 Answers
Based on the combination problems involving the coil kill wire and the PTO activation, I would suspect the PTO switch is bad.
I do not have a schematic for the 300x, however I most of the functions are comparable to the LA 145, 165, 175.
The PTO switch is a multifunction switch. It will have 3 to 4 different functions internally. On the LA 175 it serves 3 functions. These 3 internal functions are independent of one another. Electronically they are known as single pole/single throw switches. In other words even though they are all housed inside a single unit they act light 3 separate light switches in your house.
One function ("light switch") controls your cranking system. When the key is turned to Start, power flows from the Key switch (purple wire) to the PTO switch. With the PTO switch off it flow out (purple/white) and goes to the Brake switch. If the Brake is set the power flows through to the starter solenoid and your engine cranks.
Another "light switch" inside the PTO switch controls the Blade Clutch. Power flows from the Key switch, in run position, (yellow wire) to the PTO switch. With the PTO switch on it flows out another yellow wire to the Blade Clutch. A DC volt meter should show 12 volts switching on and off as the PTO is turned on and off.
The third "light switch" completes a Ground Path. This ground path is a totally separate pathway running through the PTO switch. The ground system is fairly complex because it operates differently under different scenarios.
To produce a spark, the key switch must be in the start or run position. While starting the PTO must be off and the brake set. The seat switch does not matter at this point.
Once the engine is running the seat switch plays a part if the PTO is activated or the Brake is released. Someone must be in the seat.
The Kill system is activated
  1. When the key switch is turned off.
  2. When the operator leaves the seat without setting the brake and turning off the PTO.
  3. When the machine is reversed while the PTO is engaged and the back up switch (RIS) is not pressed.
So there are three different paths to ground; any of which can kill the engine by grounding the coil. Except for turning off the key, all other grounding functions flow through the "grounding light switch" in the PTO.
Because you have a combination problem, the Coil kill wire is grounding the engine and the Blade Clutch won't activate the blades; both of which are affected by the PTO switch, odds are you have a bad PTO.
Obviously there are too many complex functions to just bypass the switch. You will have to replace it. The part number you need is AM135131. You can do a site search to locate and order this replacement switch for about $26.00 including shipping at this site: GreenPartStore Parts for John Deere Lawn Tractors John Deere Lawn Garden...
Posted on Mar 29, 2015
  • 2 more comments
  • Anonymous Mar 30, 2015
    Okay I'll order the switch and try it. Thank you so much for your help.. There is no telling how much John Deere would have charged me to fix it thanks again
  • Kprime
    Kprime Mar 30, 2015
    You are welcome.
  • Kprime
    Kprime Mar 30, 2015
    The only other thing I could think off that would affect both systems would be a cut wiring harness.
  • Kprime
    Kprime Mar 30, 2015
    while studying the schematice last night, I noticed that everything I said about the PTO swtich is also true of the Key switch. The grounding circuit goes through the Key switch just like it goes through the PTO switch. The clutch power goes through the Key switch just like it goes through the PTO switch. So those two systems both pass through the key switch and then through the PTO switch. The problem could be in either switch. Do you have a Volt/Ohms meter?
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
Blades won't engage on John Deere x540.
I would remove the PTO switch and have a Deere dealer test it. Also on the 500 series the PTO operates through the ignition control module which is under the dash, you can see it when you raise the hood. It is black and about 2" wide x 3" long and 1" thick.
Jul 29, 2017 | John Deere Garden
John Deere la125 somebody rigged PTO so it's engage always and causing mower not to start or starts hard.what am I looking for to correct this?
find the wires to the PTO and trace then back to the switch
connect correctly(Probably done because of a faulty switch in the first place )
May 26, 2016 | John Deere Garden
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
John deere L20 tractor mower will not start. it wont even turnover. i think it has something to do with the pto kill switch
There probably several kill switched, on the PTO and another under the seat. For diagnostic purposes only the switches can be jumped with a wire to see which switch is bad. Once it is located remove it and replace it with a new one.
May 21, 2014 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
John Deere 314 garden tractor PTO mower deck kills engine
bypass the safety switch on the seat to test that one
Aug 13, 2012 | Garden
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
355 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
