Question about US Acoustics Car Audio & Video
I got a us acoustics usx.my misfit is burnt.will it work if I replaced it
Can I put a nuther misfit in my us acoustic. And it work good
Please clarify your question. I have no idea what a "misfit" is in regards to what I presume is an acoustic guitar.
Mar 29, 2015 | Music
Red light is on amp wont work worked before then all of a sudden the light came on?
There is a possibility that there is a cable which was coming in contact with metal wearing it out eventually and causing a short making the amplifier go into protect or you have a shorted/damaged speaker. Check your cables. With the info you provide, thats the best i can do hope this helps dreamsystems
Feb 08, 2011 | US Acoustics USX-4065 Car Audio Amplifier
How many watts
  • 120 watts x 4 at 2 ohms
  • 240 watts x 2 in bridged mode
  • Jan 12, 2011 | US Acoustics USX-4085 Car Audio Amplifier
    So i have this usx 4085 that someone threw in with some twelves on a deal, now is it even worth it to hook them up together or just buy another amp?
    It depends on the quality of the 12s and voicecoil configuration.
    Do you know the lowest impedence the amplifier will operate? is it bridgeable?
    Howabout any low pass crossovers built in?
    I would wait for a better amplifier than risk damaging the 12s if they are worth anything.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Nov 25, 2009 | US Acoustics USX-4085 Car Audio Amplifier
    My amp plays but it smokes
    Please, Please, stop using it, the fact it plays is a malfunction in itself, so get it fixed or get a new one b4 you light your car on fire...
    Oct 07, 2009 | US Acoustics USX-2100 Car Audio Amplifier
    No sound out of it, took it apart and found one of the Irfz44n mosfets burned up and the resistor right beside it burned too, What would cause this?Thanks
    Hello rjhunting,
    Most often the output MOSFET's and associated circuitry will burn out when the amp draws excessive current. And excessive current draw is most often caused by operating the amp into an impedance that is too low. Of course, depending on the age and actual use, the amp could have failed from normal use. The US Acoustics USX-4085 is a relatively good quality low-end amp that was manufactured with excellent components.
    All of their amps manufactured after 2001 carried a 3-year warranty. But when operated in "tri-mode", with normal speakers and a subwoofer, the subwoofer minimum impedance rating was 8 ohms. And the normal speakers should be operated through a high pass capacitor while the sub needed a 15.9 mH low pass filter inductor.
    The MOSFET's and resistors can probably be replaced at a qualified electronics shop. If you are somewhat handy with a soldering iron and have a controlled temperature soldering station, you can do it yourself. Parts are available from: http://www.allelectronics.com/ and http://www.mouser.com/
    Hope this helps.
    Sep 27, 2009 | US Acoustics USX-4085 Car Audio Amplifier
    How many watts is it?
    85 watts
    Hope this is a fix Ya.........
    Feb 22, 2009 | US Acoustics USX-4085 Car Audio Amplifier
    My suggestion is to take it to a local repair shop and have them look at it
    Dec 06, 2007 | US Acoustics USX-4065 Car Audio Amplifier
    Car Audio & Video Logo
    42 people viewed this question
    Top US Acoustics Car Audio & Video Experts
    xxxxxx xxx
    Are you an US Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
