Question about Bosch Washing Machines
My Bosch SuperSilent dish washer stopped halfway thru a wash cycle and now does not want to come on, yes the power supply is on.
    Master:
  • 416 Answers
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Replace if defective (note: uncommon problem). Dishwasher Repair Help Troubleshooting and Parts
Posted on Mar 29, 2015
Washer_tech
  • 164 Answers
SOURCE: Washer keeps draining...
sounds as if your drain hose is too low. you need to have the hose higher than the water level in the tub. if the hose is below the water level the water will just pour right out
Posted on Nov 11, 2007
  • 3230 Answers
SOURCE: Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Posted on Mar 28, 2009
  • 98 Answers
SOURCE: spin cycle won,t spin. starts then stops
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Apr 01, 2009
beltronic205
  • 1466 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
BIKER T
  • 909 Answers
SOURCE: My washer stops half way through the cycle and
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Posted on Jun 13, 2010
My Bosch SHU436UC/17 goes thru its cycle OK, but dishes aren't very clean. During the wash, the water isn't very warm, but at the end of the cycle, the dishes are very hot. Any ideas?
Is the water supply hooked up to the hot water are you rinsing the dishes before you insert them in the dishwasher did your dishwasher low on
Nov 28, 2015 | Bosch Dishwashers
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch wfl 2050/2060 washer door is jammed and will not open
talked with bosch rep-- said there is no manual door release
Jul 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Rinse agent cycle
Visit Bosch web site and get a user manual. Or tray the authorized service center
May 02, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
He3t washing machine
F02 is a drain problem. I took the back off the washer and cleaned out the drainage hose and I guess its a holding tank before it goes out. Both were very clogged with STUFF cleaned it all out now it works better than ever.
Feb 03, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Washing Machines Logo
103 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
