Question about Westinghouse Televison & Video
How do i exit the jpeg screen on a westinghouse DWM55F2Y1
    Top Expert:
  • Westinghouse Master
  • 75,571 Answers
Refer its user manual for details. Gopakumar Gopalan Google
Posted on Mar 29, 2015
My Westinghouse tv, Wisdom share smart cloud tv is stuck on the erasing system screen. How do I fix that?
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 16, 2018 | Westinghouse Televison & Video
My Westinghouse tv continuously displays the input source on the screen.
Jan 17, 2018 | Westinghouse Televison & Video
How do I remove Blind Commentary from my Westinghouse, flat screen television?
get the on screen menu up , navigate to the section for audio , turn off any blind help or assist , go ok and exit
May 26, 2016 | Westinghouse Televison & Video
Service mode Westinghouse tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Dec 10, 2014 | Westinghouse Televison & Video
Westinghouse tv screen wont stop blinking different colors
I just had the same problem with my 50Inch. I tried calling the customer service number and waited three different times. The line just hung up on me as I became the next caller. Absoultely insane. I will never buy a westinghouse again. However, my tv was blinking from black to white to red to green to blue- the entire screen. I tried multiple things. eventually i held the EXIT button on the factory remote. This seemed to exit the safe mode of whatever it was in. I then changed the HDMI plug to the #2 port. Currently it is working normally.
Feb 26, 2013 | Westinghouse Televison & Video
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
Ipod touch second gen wont save photos
  • Shake And Save, it’s a print screen program for Windows Mobile.
  • Just shake your mobile, and the app will save the screen as image.
  • Supported 4 image formats (.Png, .Bmp, .Gif, .Jpeg)
  • Choose the format and start the ShakeAndSave, when you want to take the print screen, just shake the phone.
  • Then press “Yes” to exit or “No” to continue the screens shots.
Hold you phone tight. DONT drop your phone while taking a screenshot
Jan 03, 2010 | HTC Touch Cellular Phone
Westinghouse DPF-01411 Digital Photo Frame
Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
Mar 30, 2009 | Westinghouse DPF-1411 Digital Picture...
Transferring photos from digital to photo frame- How to? Please
If you need to transfer to your computer just connect the USB cable from the camera to the computer, switch the camera on, turn the dial to View and Voila! A connect icon appears on the camera screen. Follow instructions on screen to download photos; develop if necessary. Presumably you will then be able to download the jpegs to your photo frame from your computer.
May 27, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
