Question about Power Acoustik Car Audio & Video
I have a power acoustik amp, it powers on but no sound. How can I fix it?
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
trintek
  • 111 Answers
SOURCE: No Sound From My Amp!
i am assuming the amp is not under warranty, if it is, rma it... if not, you have nothing to lose from trying this.
hitting it and having it work usually means something is loose or broken, remove the case and extract the circuit board.. clean all parts thoroughly using a good electronic or contact cleaner, i use crc qd electronic cleaner as it is cheap and available at most auto supply stores, just make sure whatever cleaner you use is not industrial duty and is plastic safe.
after the entire thing is cleaned (coils, caps, anything resembling dust), check with a magnifying glass for any broken solder joints, you can also very lightly touch components and see if they move.. this sounds like either broken solder joints, extremely dirty contacts, corrosion, or dry caps.. you can usually locate dry caps by looking for corrosion around the cap and discoloration on the top of the cap.
hope this helps, and hope you get it running; the ps2 amps are pretty nice when it comes to accurate sound reproduction.
trin
Posted on Nov 16, 2007
  • 19 Answers
SOURCE: Power Acoustik
the amp shouldnt even lite up w/o the ground attached.
Posted on Dec 30, 2007
zzedly
  • 300 Answers
SOURCE: POWER ACOUSTIK - A1800DB how to fix protection mode
If I don't ask the stupid questions first, I always get burned! Have you tried removing both the +12V and remote connections from the amp and letting it sit for a few minutes? If the amp doesn't automatically reset (and you have removed the condition that caused it in the first place), your amp may need repair, as it might have shorted something internally.
Posted on Mar 12, 2008
  • 149 Answers
SOURCE: amp and subwoofer problem
try using an ipod or mp3 and hook it up directly to the amp input section-if its lit up and you get sound then youre not getting signal from your deck and youll have to track that problem down at the deck-if you still dont get any sound by connecting directly into the amp inputs then you may want to check all amp settings and be sure that your set up right and if it has external fuses make sure that they are all good and if it still wont give you any sound than take it in and get it checked out-hopefully its just not getting any signal cuz if its the amp then sorry to hear it-but good luck
Posted on May 21, 2009
I have two 12inch subs with a 5500 watt amp by power acoustik the problem im having is my battery is always dead somebody told me to use a boat battery is that a good ideal
your alternator can't keep up bro try using a distortion that may help if your luck thats alot of power i bet it sounds kick *** while it lasts i hope your not driving a small car
Oct 28, 2010 | Power Acoustik BAMF5500/1D Car Amp
I have a power acoustik bamf 2000 class d amp and i think when i had it unhooked the positive and negative speaker wires might of touched for a few minutes and now the amp comes on no protection light just...
internal components are very sensitive to things like that. sounds like you shorted out some of the fets internaly .. i recomend a complete diagnostic and proceed to repairs.
May 06, 2010 | Power Acoustik SL2-2000 Car Audio...
Amp has no sound?
Yeah, u are probably right. If u are good enough with electronics it is a pretty easy fix
Feb 07, 2010 | Power Acoustik OVN1-4000D Car Amp
I have a power acoustik bamf 1600/4. not working 5 hours later
use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
Dec 29, 2009 | Power Acoustik BAMF1600/4 Car Amp
How do you fix a blown fuse circuit in a lt1440 power acoustik amp
Just replace the blown fuse with one of the same amp rating... If the fuse keeps blowing you'll wanna recheck your wiring and make sure you don't have a short somewhere.
Sep 20, 2009 | Power Acoustik LT-1440/2 Car Audio...
Amp and subwoofer problem
May 21, 2009 | Power Acoustik BAMF2000/1D Car Amp
Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Feb 13, 2009 | Power Acoustik PTID-8960 Car Video Player
Car Audio & Video Logo
90 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
