Question about Sanyo Televison & Video
My sanyo TV all of a sudden won't turn on manually r with remote, it was fine when I turned it off last night
    Top Expert:
  • Sanyo Master
  • 75,452 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Mar 29, 2015
  • 5 Answers
SOURCE: Protron pltv3250 32 in. lcd, no power, no lights
You will have to have the set checked by someone to confirm this,
but most likely there is a problem with the TVs internal power supply.
Posted on Jan 25, 2009
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
  • 12 Answers
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Posted on Dec 16, 2009
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
  • 4 Answers
SOURCE: LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
Posted on Jan 23, 2010
RixsFixes
  • 2200 Answers
SOURCE: how do I turn on
With the TV still in standby mode open the front panel tray by pushing on the triangle that is marked there. Then push the third or the fourth button. See diagram below (buttons framed in blue). The TV should come out of standby and operate.
These buttons are also used for going up or down the channels - press and the TV will cycle up or down each time. You can also use the second button marked F on the TV front panel to cycle sequentially through volume and other menus then adjust these up or down by using the buttons framed in blue.
See diagram below. Thanks for using FixYa and please remember to leave a vote for the solution.
Posted on Jan 13, 2011
The tv comes on then clicks off
Mine I will do this if the cable box is not turned on fist.
Feb 28, 2014 | Sanyo DP42849 42 in. HDTV
The sound on my TV has suddenly stopped working
check all wires are firmly in place, especially the scart lead, and just give them a little push to make sure, if that doesnt work, try unplugging your tv from the mains and wait 5 mins, plug it back in, wait another 5 mins, and turn on, if that doesnt work, contact the company's customer service line.
Mar 17, 2012 | Sharp Televison & Video
Can not change channel on my Sanyo LCD TV
I have not solved it but, when I play the dvd player it seems to make everything else work....
Feb 14, 2009 | Sanyo Televison & Video
Hello; I bought a RCA replacement remote at Walmart last night. It is model RCR312W I have a Sanyo 15" TV that is connected directly to cable I tried programming the code into the remote and it...
The universal code for most is 049 for a Sanyo TV. With your universal remote you press the code search key until it illuminates and then you press and release the TV key. Next enter the three digit code (3 digit remote code page) and the indicator light turns off.
If you enter in the wrong code the light will flash rapidly. Aim the remote at your tv and press the on/off key. If your tv turns off then you have found the right code!
Try these codes for your Sanyo TV also: 054, 069, 023, 025. If those do not work then also try: 004, 013, 049, 108, 110, 180, 209
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
The best solution is to buy a replacement remote for the make and model television that you actually have.
https://www.replacementremotes.com/SANYO/Remote-Controls
Feb 10, 2018 | Televison & Video
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
