How do I know what to fix?
Started a load it seemed to be sensing and then started making this horrible grinding sound. Removed clothes from washer tub and noticed that the tub is not moving freely seems to be locked. I did the self diagonistic on it and it states that no problems are detected for this unit. please help
  • 3 more comments
  • Tammy Gibbs Mar 29, 2015
    my machine has the rotor/stator type drive motor, and a locking/unlocking clutch mechanism, would that still have a bearing? I don't think so. any other suggestions
  • Tammy Gibbs Mar 30, 2015
    my husband took off the coupling assembly and the tub turns, put the coupling assembly back on the tub will not turn.
  • Jorge Rendon
    Jorge Rendon Mar 31, 2015
    the stator may be bad indeed. Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. however let me ask u a question u say it will not turn with the coupler back on? can u try to turn the motor drive shaft itself by hand? it may be froze up. try to turn the transmission shaft by hand also see if its froze up>?
  • Tammy Gibbs Mar 31, 2015
    Ok my husband turned the shaft from the bottom of the washer and it and the tub turn.
    I really appreciate your time and effort to help us.
  • Washing Mach... Master
  • 5,323 Answers
Sounds to me like either a tub bearing has gone out or u have something stuck in between tub and housing, it does happen, a bra wire, pin, nail, bobby pin etc even coins. remove housing and check more closely
Posted on Mar 29, 2015
Testimonial: "Thank you very much for your prompt response."
  • Jorge Rendon
    Jorge Rendon Mar 30, 2015
    wow it slipped me but yes u may have a transimssion locked up with bad gears lets hope not
SOURCE: Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Posted on Feb 07, 2007
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
  • 90 Answers
SOURCE: Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Posted on Feb 10, 2008
  • 76 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
My washer wont rinse. It seems to have a hard time spinning, any suggestions?
do you hear the motor running ,it will drain but no spin,this has no belt in it it's built just like a whirlpool washer because whirlpool owns maytag now and this washer has a motor coupling,i would check this first,do you know if the agitator is working or do you hear a grinding noise when it's running?watch this video and you don't have to disconnect the wire harness to the motor if you don't want to,i don't just put motor off to right side still connected
http://www.youtube.com/watch?v=9K1KHEogf3c
Apr 09, 2013 | Maytag Centennial MTW5800TW Top Load...
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
Squealing on the start of spin cycle
the gear case may be bone dry, i would check this. make sure everything is aligned as well. if there is a belt, check to make sure it is tight and not too lose. i suspect that the repairman has done a horrible job.
Mar 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Whirpool washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise in wash cycle
This is normal, because your washer will make sounds that you may not have heard from other washer.
Jun 07, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Feb 10, 2008 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
