Question about Coleman Electrical Supplies
How do I wire a Coleman powermate 4000 - Coleman Electrical Supplies
  • 195 Answers
SOURCE: Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Posted on Jan 23, 2009
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Posted on Nov 23, 2009
  • 342 Answers
SOURCE: i have a coleman powermate generator that my dog
look for a manual with diagrams
Posted on Apr 04, 2010
  • 5603 Answers
SOURCE: Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Posted on Apr 16, 2010
Testimonial: "Thanks for info. I had it solved. I found the 130uf 200V rated cap was bad. 12 volts to the brushed did re-energize the field, power is operating. TY"
Looking for wiring diagram for my coleman powermate PM54-4000
http://www.powermate.com/productmanuals.php?cat_id=3
May 07, 2016 | Coleman Electrical Supplies
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
Coleman Powermate Powermate 5000W Generator
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
May 07, 2010 | Coleman Electrical Supplies
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Where can I get parts for Blue Max 6.5hp blue max
http://www.powermate.com/productmanuals.php?cat_id=3 for manuals and parts diagrams
Mar 16, 2010 | Coleman Powermate Powermate 5000W...
Coleman powermate 4000 pops circuit breaker on the 220 side.
Don't know what you mean by "on the 220 side".
The generator has two joined circuit breakers that each are 110 volts. Between the two is 220.
If just one of those is opening WITH NOTHING PLUGGED IN, then there are only a few explanations.
1. There is a short in the wiring or the wiring has been tampered with and connected incorrectely.
2. The switch that switches the mode from 120 to 240 has gone bad, possibly with a welded contact. This would occur if the switch is changed with load on the generator. This could put a driect short on half the generator winding and cause one of the breakers to blow.
3. Worst is a winding short in the generator. Fortunately this is the least likely.
4. The 220 receptacle has been broken and insulation failed shorting one terminal to another.
Nov 14, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman generator 4000
powermate went out of business , but here is a website http://www.powermate.com/contact.php
you can probably get a off/ on switch at your local small engine repair shop. it probably can be any switch for a gen.
Sep 18, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
27 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
