Question about Ovens
Having problem with the oven - Ovens
  • Barry Coates
    Barry Coates Mar 31, 2015
    Hi annie , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Ovens Master
  • 5,323 Answers
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Posted on Apr 18, 2015
Do you have a thermonstate for a preway wall over - model 501-1
  • Range/Stove/Oven Thermostat Parts In Stock from ... www.repairclinic.com/.../a13c24/Range-Stove-Oven-Thermostat-Parts Shop for your Range/Stove/Oven Thermostat from our ... What is a model ... Repair Help. SEARCH. Range/Stove/Oven. Thermostat. Clear All. Range/Stove/Oven Thermostat ...
  • Preway Wall Oven Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Preway Parts Shop the best selection of Preway wall ovens repair parts and accessories at Sears PartsDirect. ... Preway Wall Oven Parts ... Model retention may be affected by your ...
  • Preway Oven - Network54 www.network54.com/Forum/124162/message/1109513545/Preway+Oven Preway Oven February 27 2005 at ... I like you was searching for information on parts for a Preway wall oven we have in our ... I have the manual on the oven. The ...
  • Mar 24, 2016 | Ovens
    Top oven does not heat-although bottom oven is ok.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 29, 2010 | Whirlpool GBD277PD Electric Double Oven
    Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
    If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
    heatman101
    Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
    Diplomat Double oven bottom oven fan works but
    heatman101
    Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
    Kenmore oven door locked need help
    heatman101
    Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
    May 31, 2009 | Kenmore 30169 Electric Single Oven
    I cannot get the oven to come on after I used the self cleaning.
    Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
     Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
    Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
    These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
    Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
    Neff U1422 oven overheating
    Hi
    Yes it does sound like faulty thermostat.
    You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
    Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
    You will probably have to remove the rear
    panel as well to get the thermostat sensor out.
    One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
    Good luck
    Hope this will prove helpful.
    Nov 22, 2008 | Neff U1421 Double circotherm Electric Oven
    Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
    heatman101
    Nov 12, 2008 | AEG D2100-4 Electric Double Oven
    OVEN TURNS ON BUT WONT HEAT UP.
    heatman101
    Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
    GE OVEN SINGLE ELECTRIC JKS05BW
    I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
    Apr 09, 2008 | GE JKS05 Electric Single Oven
    Ovens Logo
    70 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
