Question about Kyocera Office Equipment & Supplies
Please help. Why does my Kyocera C6370 keep saying please remove your hand or something blocking the screen when there's nothing over the screen
3 Suggested Answers
SOURCE: Remove and check cartridge
Mine says the same. What shall I do?
Posted on Dec 14, 2008
zsomboribala
  • 11 Answers
SOURCE: I am getting a black
The problem is in the fuser roller.
Try to open it and see if there are any damage in the red-orange teflon roller.
The other problem can be in the trasform roller.
It's under the drum. I will write down what can you du, but first open the rear unit at the back and inform me about how it looks like.
Open with pulling gray handle. There is a green square mark in the left. Grab it and pull. Now youz will see two rollers. Please tell me everithing about the upper and the lower roller. Rotate it by the gears (360degrees), and see every side.
Posted on Oct 11, 2011
Kyocera not feeding paper.
Open paper tray, locate the feed roller (small rubbery wheel) and moisten a cloth. Gently clean the roller to remove build up of paper dust from it.
Also worth using is some "anti static foam cleanser" on the cloth to help deep clean the rollers, or the pre-moistened "Screen wipes"
Also check there is nothing blocking hte paper path, remove paper cassette, and toner catridge (and drum if I recall correctly) and see if you can feed a sheet of paper MANUALLY from tray up into the "imaging chamber" where the toner lives. If this feels too stiff, there could be an obstruction in the way, fragment of paper scrunched up after a REAL jam, or fault sensor arm.
If you find something and can remove it, reassemble, and test
Dec 10, 2014 | Kyocera FS-4000DN Laser Printer
I have a gateway computer well Iwas using my kyocera rise as a modem well my house power surged and I had to trade it in for the same kind but now I can't get the new phone to connect it keeps saying that...
For a "driver problem", access "Add/Remove Programs" and uninstall the software for the Kyocera USB modem.
Shutdown and reboot your computer, and Windows should re-install the correct driver software.
Jun 30, 2014 | Computers & Internet
Kyocera Domino 1300 keeps restarting and won't go past the start up screen that says Kyocera, then shuts off and turns back on again and does the same thing over and over. I tried removing the b
quit messing with the battery for starters. you want to startup into safe mode. If you can get into safe mode then its a software problem, if not then it is a hardware problem. also if the power cord is plugged in and the battery is out of the computer and the problem persists then it has nothing to do with the battery.
Aug 25, 2012 | Computers & Internet
Kyocera FS-2000D CALL SERVICE 0150:0171913
Your machine has a FIRMWARE problem. You must call a Copystar or Kyocera Technician to resolve .
Aug 06, 2009 | Kyocera FS-2000D Laser Printer
My trackball isnt not responding when i selected something
Okay for future references do not bring your phone into the bathroom :) because this can cause water damage to the phone due to the humidity in there. Anyways there is something you can do remove the trackball to find out how click here after its removed you can check for water damage or any water that has collected there if you do find water damage or just water turn your phone off! Next after that I would leave the phone in a dry place to let the water evaporate do not stick "kleenex" or paper towel in there because u can get peices stuck in there and can cause problems for the trackball later on if you really want to stick something down there to soak up the water use cloth that has no chance of getting stuck and leaving something behind so after that reassemble your trackball with the ring and remember dont force it or you could break the ring and it should work if not just post back and I'll be happy to help you again.
Cheers,
Kyle
Jul 02, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Error message - "chassis locked"
check the toner on the left had side is a locking mechanism... make sure toner is in correctly and that switch is locked...
Mar 23, 2009 | Kyocera Mita FS-1020D Laser Printer
Kyocera s4000
MetroPCS provider
Kyocera Mako S4000
Screen is blank, no visual.
Phone works but the screen is blank.
Can this be fixed? What are the steps to fixing this blank screen?
Jul 10, 2008 | Cell Phones
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
