E00002-000 Error is Showing found Supply Voltage is Ok But I can't clear this error. plz suggest me how to clear this error.
  • 2072 Answers
SOURCE: E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Posted on Apr 14, 2008
  • 114 Answers
SOURCE: showing hammer voltage 2 error
the problem comming from logic board. need to change the logic board and hammer bank cable at the same time.
Posted on Jan 30, 2009
pineworks
  • 4041 Answers
SOURCE: The error message "Service Error 6A00" and cannot fix it. HELP!
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
pineworks
  • 4041 Answers
SOURCE: THe screen is showing ERROR...Carriage jam open
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Posted on Feb 25, 2010
SOURCE: Kyocera km 4050 showing error code cfb31 how to clear it
hello,
This error has to connect the connector (red, green, white, black, black) in the wrong place in panel. yc1 - yc9
Posted on Jun 03, 2013
Toshiba e-studion287cs have error code COA2 any one with knowledge on how to clear that error code
Ahaaa grasshopper.... that is a "C 'zero' A2", not a COA2... here's what I found:
Code C0A2
Description
Low voltage power supply fan error
Causes
Is the fan (bottom right of the front) of the low voltage power supply block working? Is the fan connector connected normally?
Remedy
Check for sure connection of the fan connector. Replace the PU board. Replace the fan motor.
I include a GREAT LINK that describes Error Codes for your unit!
USE THE DROP-DOWN arrow to see all of the codes offered!
Anthony
Toshiba Studio 287CS Error Codes List page 1 from 14
Nov 21, 2017 | Toshiba Computers & Internet
Have samsung sw5ousp 5kg it is showing 4e water error any help b great thanx in advance
The Error indicates that the water level did not increase or fill in time to the machines estimation . 4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON. Check that the water valves are fully open check that any fill lines that have washer hose filters in them are clean check you source water pressure is OK
Apr 18, 2016 | Samsung Washing Machines
How to reset error code e000.0000
the fixing unit temp. is abnormal. check the supply voltage compare with the printer req. voltage.
check the heater contact points if contaminated clean/replace it. if found ok check smps next dc card. before doing these checks do clr. all error code.
Dec 22, 2014 | Office Equipment & Supplies
E00000-0001
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
May 29, 2014 | Canon ImageRunner 3045 | IR3045 |
C0500 error code
Hi, Sir;
I believed this machine come with two heater lamp, change this two lamp position, and also thermistor have to be contact heat roller perfect, try it see what happen. good luck
Jan 11, 2014 | Konica Minolta Di3510 Copier
0500 ERROR CODE
I am also facing this trouble, with Di3510. some time machine work for many copies fine. then suddenly the 0500 error code appear. I checked complete fuser unit... Both lamps are ok, Thermo switch is ok, i checked both thermistors and in my view they are ok (checked with multimeter while warming them). I first reset the code as mentioned in the service manual of this machine. the code can remove but it comes back after some time. I checked the Electricity voltage as this machine is 120v input. Voltage are ok. Then i ask my Electronic board expert to check the Power supply and he told me that the power supply is ok... just some dry sold he found. So until now i am not able to detect the trouble even though i arranged another fuser unit of the same machine and it also gave the same error code c0500. As i am a Technision of copiers. Please give any good suggestion if any one have. Thanks
Jan 09, 2014 | Konica Minolta DiALTA Di200 Copier
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
Dec 13, 2009 | Tally 6306 Matrix Printer
Canon Imagerunner 3570 error code
if u r still having this problem with the imagerunner 3570 u can try this:
press * 2&8 together then * again
go to function
then to clear
select eroor then ok that should take care of ur issue
Jun 08, 2008 | Canon ImageRUNNER 3570 Copier/Printer
k24674
jasbo
jasbo
