Question about Fisher and Paykel Washing Machines
Changed board fault 9 comes up - Fisher and Paykel Washing Machines
    Novelist:
  • 251 Answers
Hi Alan,
You need to size the machine correctly, it would normally have instructions with the new replacement controls. I cannot help you without a model number, there are 3-5 various methods pending on the model.
Posted on May 10, 2015
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: i have just changed the brown control board and
Hi and welcome to FixYa. I am Kelly.
You did not provide a make and model number so here is my best model to problem guess....
Your new control board is missing the size information.
AQUASMART-SIZE-SETTING. Size information must be programmed when a Motor Control Module or Display Module has been replaced. If the size is not set, the display will show fault code 9, or the water levels and wash actions will be incorrect. If the machine displays fault code 9, the machine must be switched off at the wall and then back on again before it can be sized.
Setting the size:
Unplug at the wall and then re-plug it in.
Press and hold Temp Up, then press Power. Wait for the 4 beeps, then set your machine size as follows to YOUR machine size:
5/5.5kg machines - press Temp Up. Cold led should light.
6/6.5kg machines - press Water Up. Low water led should light.
7/7.5kg machines - press Spin Speed up. Spin hold led should light.
Power off, try a programme.
Thanks for using FixYa!
_____________________________________
From the Tech Sheet:
IWL12 and GWL 11 are different models. One of the two procedures will work for your machine.
The machine size must be set into the machine
memory if a Motor Controller or Display Module has
been changed.
To set the size:
1. Turn the power on at the power point and off
at the console.
2. IWL12 - Press and hold the FABRIC CARE
button, then press the POWER button. This
will present a set of options in the LCD
screen. The LCD screen has within it a
number of options. Push the Adjust button to
highlight the 650mm (L) machine size.
Pushing the POWER button will lock the size
into the module’s memory.
GWL11 – Press and hold the WASH TEMP
UP button then press the POWER button.
Press the SPIN SPEED UP button (the HOLD
LED should be on.)
3. Press the POWER button to return to normal
operation.
Kelly
Posted on Mar 20, 2010
Testimonial: "Thankyou, this was very helpful"
SOURCE: changed board fault 9 comes up
Follow instruction to re-select machine size. 7kg = 600
Press left scroll key and high efficiency key at the same time until select size appears. Select size and power off to store.
Machine should then start up OK
Posted on Nov 08, 2012
Fault code 9 fisher and paykel
With the board replacement, did you program this board for this unit? If not, thats the problem you have now. Good Luck
Aug 04, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Intuitive Iw509nw fault code 9 what's it mean
the size of the machine needs to be set. if you recently replaced a board the first thing you need to do is 'size set' the machine and instructions should come with the board. holding wash temp up/down and pressing power should get you into the menu, though it's too much to explain here.
Aug 16, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
The error code #9 is a machine size error code. The error code can come up if the board was recently replaced. Programing the washers control board wrong could also cause this error.
May 14, 2012 | Fisher and Paykel Washing Machines
F9 fault. I replaced the main control panel, with the led display. Still F9 fault after 9 sec. Also get a high pitch humming sound at times. Heats most of the time & F9 does not always come up when...
That sounds like a problem on the invertor board. Unfortunately there is not a lot to be done on the board without a service manual and the needed experience.
Hope that helps.
Feb 03, 2011 | Kenmore 62622 Microwave Oven
"Time for service" light comes on after the car
Your mechanic may have forgotten to reset the light. Also if the time for service light is your check engine light a fault code may be stored in the vehicles on board computer. Have the codes pulled to determine if a fault code is present or not. If there are non you can have the light reset, however if there is a fault code and you just reset it the light will keep coming on until the problem is corrected.
Jan 18, 2011 | 2000 Saab 9-3 Viggen
Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
May 26, 2010 | Washing Machines
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
Not coming on-tries 9 times Then stops
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jul 02, 2009 | Televison & Video
Washing Machines Logo
52 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
