Machine will not turn on no lights - Washing Machines
    Master:
  • 420 Answers
I'm assuming your referring to a washing machine, but you didn't specify
It doesn't work at all
  1. No power to the washer Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
  2. Lid switch The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Washer Repair Help Troubleshooting and Parts
Posted on Mar 29, 2015
  • Washing Mach... Master
  • 5,323 Answers
No power of blown fuse in panel? check power to the terminal with a meter
I just got my Juki 1541 DNU walking foot machine. The light comes on, like the machine is on, but when I push the presser foot nothing happens.
juki-1541-detail-pupyr0ualaj20obfvyre1rzh-1-0.jpg Both the motor and the light work off the switch box separately USUALLY.
1. Look under your machine to see where the cord to the light is coming from. If the light cord is coming directly from the switch and the light is on, we can check that off our problems.
2. Now we need to see why the machine isn't moving. If you have a fairly new machine, it probably has a Servo motor which doesn't really make any noise when it runs. If you have an older larger motor, you may be able to hear the motor run when you turn it on. One way or the other, you still need to make sure if the belt is on both the motor and the hand wheel. Using a flash light or other bright light, follow the path under the machine of the black belt for your machine. It should go around a pulley on the right side of the motor and go up through the table and around the hand wheel on the right side of the machine. Because of the belt cover that is on your machine to keep us from getting things caught in the belt, it is almost impossible to see from up above. There is also a cover on the end of the motor sometimes and its hard to see in it.
3. If your belt does connect the motor and the sewing machine head as it should, press on the foot pedal while it is plugged in and turned on. If the motor pulley turns but the machine doesn't, your problem is in the machine. If the motor pulley doesn't turn, your motor is probably bad. If the motor turns, and the machine doesn't, try to turn the handwheel on the machine and see if it is jammed with thread or something else.
Once you isolate the problem, post again and we'll go to the next step. :)
Jul 03, 2017 | Juki Sewing Machines
How does a Saeco Magic De Luxe Espress machine know the dregs drawer needs the be emptied and turns on the light? Does is just count the pucks that are put into the drawer or is there some type of sensor?
Simple answer is it counts how many coffees have been made. If you turn the machine off and then empty the dredge drawer the machine doesn't know this. and the light will remain on. Leaving the machine on when you empty the drawer lets the machine know that you emptied it (15 seconds out) and it will turn the light off.
Oct 07, 2010 | Saeco Magic De Luxe Espresso Machine
No water/coffee comes through? the temprature indicators doesnt light up?
The POWER LIGHT for the 889 is RED and located on the LEFT of the center cowling
The BOILER LIGHT for the 889 is YELLOW and located on the RIGHT of the center cowling
If you turn on the power to the unit (the INNER SWITCH on the RIGHT SIDE) the RED light should turn on, showing that the machine is powered. At that point the YELLOW light should also turn on for about 10 seconds, at which point it will turn OFF with an audible CLICK.
If the RED light does not turn on then you have a very dead machine.
If the RED light does turn on but the YELLOW light does not then you have a half dead machine.
Opening up and repairing the 889 is not for amateurs. High voltage, heat and pressure inside.
If you decide to bin the machine I would appreciate getting the drip tray from you as I have lost mine.
Graham Leach
Sep 05, 2010 | Dualit Espresso 889 Espresso & Coffee...
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Sewing Machine light flickers/dims while sewing.
There may be a loose connection. If this is a brand new machine the warranty should cover the repair.
Check the return policy at Sears/K-Mart as it may be better to return it for a replacement.
Feb 20, 2010 | Kenmore Sewing Machines
How do I get the water heater to turn back on after the descaling.
The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it’s self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. You will have a steady red light and the green light will be blinking. Refill the water tank again with fresh water, close then open the steam knob, this will clear the red light and your ready to go.
Nov 07, 2009 | Solis Palazzo Espresso Machine
Washing machine wont turn on
If the lights flicked when you tapped (hit) the fuse box or breaker box then the problem is in the box, not in the machine.
Jul 29, 2009 | Washing Machines
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
