The extra rinse function is permanently on - when I press the button it doesn't click in and then out like the other buttons - it doesn't stay clicked in. I just bought this washing machine second hand so just discovered this issue now. Can I fix this if I remove the fascia? Thanks, Amy.
Some can be taken apart and inside is a spring loaded connection that pushes the button back out sometimes hard water and soap and debris can jam and stick the spring and u get what ur getting? you may be able to by pass the extra rinse by disconnection the prongs to it and taping them up?
Hi
First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door lock-switch assembly. If the door
lock-switch is also fine then the control board should be replaced. Hope this
helps...please post back for further assistance.
Daniel
