Hi where can i find 2 original tweeter - Audio Players & Recorders
    Top Expert:
  • Audio Player... Master
  • 12,962 Answers
If the manufacturer cannot help you, your best bet is cross your fingers and check for similar units on ebay or craigslist.
Posted on Mar 29, 2015
Need to replace tweeters. Anyone have specific info on aftermarket tweeters that will work
Replace tweeters with units having the same impedance as originals so amplifier loading is the same.
If unable to get exact replacement for unit, then it is important that you also replace the corresponding tweeter(s) on other channel since all speakers sound different and have different efficiency. Result will be unbalanced sound.
Mar 12, 2015 | Audio Players & Recorders
My jamo d115 speaker tweeter distorts or rattels when any serious bass kicks in, how do you stop this?w
Possible this is a distortion from the Amplifier if the speakers are not damaged. however it is important to switch the speakers to confirm if the fault is relative to the particular channel in which case the amplifier is faulty. If not the speaker can be the culprit. All what is needed is to reduce the BASS level a bit lower when the volume is increased so as to allow the cross over to work. Also if teh cross- over network is faulty within the speaker the bass can vibrate on the tweeter.
Dec 01, 2011 | Jamo Audio Players & Recorders
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
How does the tweeter on the px525c install,
when you instal these units you place the woffer in the place ware you put the normal speaker and put the tweeter in the spot ware the tweeters go in your car if it has the spot for the tweeters if it dont you can make a spot for them just make **** you put the woffer wires in the spot marked woffer and the tweeter in the spot marked tweeter the crossovers can go ware ever its best for it to connect to the original speaker wires in your car good luck and i hope this helps
Aug 06, 2010 | Clif Designs PX525C Car Speaker
Find original replacement tweeter for HB1
just buy the same wattage rating, same ohms rating and most specially the same diameter, price depends from the name, there's a lot on the internet
Jun 07, 2010 | Heybrook HB1 Speaker
KEF KHT6000ACE TWEETER DIED. HOW CAN I GET A NEW SPEAKER?
if the original KEF tweeter is no longer available there are other brand tweeters that should fit as a replacement option. just contact a repair center (us) and you can get options.
cathy@speakerex.com
Jun 13, 2009 | KEF Audio KHT6000 Speaker
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Tweeter and door speakers to fit a Lexus EX 300 w/Levinson factory system
I found that they can hold up to 6 1/2" speakers and 2" tweeters. I'm not sure the specific mounting depth but i can almost assure you there wont be any 6 1/2" speakers that require a whole lotta space
Feb 22, 2008 | Cdt Audio Eurosport ES-100 Car Tweeter
Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
55 people viewed this question
 Grubhead
Grubhead
