Question about Sherwood Audio Players & Recorders
How to hook up antenna on sherwood model rv5030r prologic receiver
Is it worth repairing a sherwood model 6030R Receiver and can you even get new parts for it???
Given that the Sherwood is a basic stereo/Dolby Pro Logic receiver, and that we have had sources where digital audio (coax and optical) are the standard for Dolby Digital and DTS for well over 15 years, and that HDMI is established now as the de facto standard for AV connections on many home AV products.... perhaps it's time to retire the Sherwood and look for something new.
Entry level price points for new, fully spec'd, AV receivers capable of dealing with HD audio, DD, DTS, Dolby ProLogiic- and ProLogic II have never been cheaper.
Sherwood is still a good brand. It has been joined by Yamaha ( RX-V377BL); Sony (STRDH750); Denon (AVR-S500BT) and Pioneer (VSX-524-K) at the entry-level price point of $249. In real terms these are probably a fraction of what you paid for the Sherwood all those years ago.
Another option is used equipment. There are some really good pre-HDMI AV receivers from Denon, Yahama and Pioneer available in the used market.
Sep 10, 2014 | Sherwood Audio Players & Recorders
Antenna is broken
Which are we talking about? AM or FM. Is it the socket where the aerial goes?
Jul 29, 2013 | Sherwood RX-4105 Receiver
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Need help hooking up surround sound with my Sherwood DAS
Sherwood's site has a manual for the model RV-4060 (click here to download) but not for the 4050. You might find it similar enough to help you. Otherwise you can try a Google search for generic Dolby surround connections. It's usually pretty straightforward. Connect the audio out from your source (TV, DVD player, etc.) to the receiver. Connect the surround channel speakers to the appropriate rear panel jacks. Fire up a source you know has Dolby encoding, turn on receiver's Dolby processing from the front panel, and experiment with the different modes to hear what you get. Just remember you can't break anything just by pressing buttons.
Jun 02, 2009 | Televison & Video
Sherwood receiver rx-4105 fm doesnt pu any frequency (just static) , am does
You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
Dec 17, 2008 | Audio Players & Recorders
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
57 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
