Question about John Deere Garden
How do you get the gear at the end of the steering shaft off to replace it on a John Deere la175 lawn tractor?
    Sergeant:
  • John Deere Expert
  • 187 Answers
It's a lock nut. But you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. But a socket on the nut below the gear and ratchet it off. That's all there is too it.
Posted on Mar 29, 2015
  • 3 more comments
  • Kprime
    Kprime Mar 29, 2015
    oops, Put a socket on the nut.
  • Lawanna Hunter Mar 29, 2015
    We removed the nut but it will not come off..is it suppose to come off the bottom of shaft?
    Are you still there?
  • Kprime
    Kprime Mar 29, 2015
    Yes, just pry it off. See attached picture
  • Kprime
    Kprime Mar 29, 2015
    It is splined inside, probably just a little stuck. Use some force.
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: John Deere LA175 lawn tractor front wheel bushings
Remove the tire and wheel from the spindle. Take a long punch or similar item and reach in the center of the wheel hub where the spindle goes. Locate the space in between the inner and outer bushing and tap the edge of the old bushing until it comes out. Now go in from the other side and do the same with the other bushing. This one will be a little easier to do since you don't have to hunt for the center space. Put the new bushings back in the same way just be sure you drive them in STRAIGHT
Posted on Sep 18, 2009
  • 229 Answers
SOURCE: MOWER DECK BELT ROUTE FOR LA175 JOHN DEERE LAWN
you can try johndeere.com you should be able to find it there.
Posted on Oct 20, 2009
How do you remove the gear at the end of shaft to place for it? John Deere LA175
It's a lock nut, but you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. Put a socket on the nut below the gear and ratchet it off. That's all there is too it.
Mar 29, 2015 | John Deere Garden
Will a John Deere LA175 lawn tractor start without the mower attachment installed?
I wouldn't think so. I know you DO need the seat switch depressed in order to start the engine.
Oct 18, 2014 | John Deere Garden
John Deere la175 mower the front center pully its
Sounds like you need a shear pin replaced where the pulley is spinning on the shaft.
Oct 07, 2014 | Garden
How to adjust the valves on a la175
that is a lawn mower number, not the engine. But if it's a John Deere LA175 and it has a Briggs single cylinder you need to adjust them to .004 ~ .006. As for how to do it. You need a manual because I am not typing all of that up
Sep 10, 2014 | John Deere Garden
Rebuild steering on john deere L120
Hi there, I am not familliar with the L120 specifically, and suggest that you go to: "John Deere Lawn Mower Manuals" online and select your model from there. In my experience with this type of unit there are two ways that the pressed gear on the end of the shaft is fitted.. Real engineers make a ferrule, usually about twice the diameter of the steering shaft, and have either a tapered end with a threadded end for a nut which often has a split pin thru the thread like a trailer wheel bearing, and a key in the shaft and taper. Machines made with a lesser labour input often have a fixed pinion which means replacing both the shaft and the pinion. If it is the tapered end with a nut, they are often very tight and cannot be removed while mounted in the machine. They may require a sharp heat and severe blow with a good hammer. I do not recommend that you do this if you are not competent as the blow to the nut can do much damage if not hit square with a cushion of copper between the hammer and nut. The fact that you do not know how to do this job probably means that it is cost effective to employ a shop which does this type of work.
Aug 19, 2014 | John Deere L100 Series
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
I have a 1020 john deere and there is hydrolic fluid in the oil put a new power steering pump on 2 years ago when it was doing the same thing Is there a ball or a setting pin that goes on the end of the...
power steering pump is mounted on front of engine where the tming gears are. Shaft leaks into crankase. Hydraulic fluid circulates through transmission, main system and power steering. Common problem with the 1020.
Apr 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
220 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
